Mar 13, 2008 - 7:13 PM
Enthusiast Joined Feb 18, '08 From usa Currently Offline Reputation: 0 (0%) |
Below is a small list that i have gathered for myself over time trying to compare bang for the buck. It just gets overwhelming when reading and searching all the products out there that you can easily get caught up in names, crazy hp numbers, and mind blowing money without actually taking a step back and realize what exactly you are getting.....and what else might be available for the kind of money. Its very easy to just throw your money at something and then realize if you sacrifice 20-30whp but save major money $$$$. When writing it all down and seeing them side by side.....part for part......dollar for dollar you can get a great handle on achieving your own personal goal. And when i was younger i always wanted like 500000000000whp LOLOLOLOLOL but now after riding in several different cars, i have found my own perosnal goal/ride/enjoyment. If you haven't been in anything faster then 14seconds try to get in a couple different setups. You may be surprised to find you don't need the hp that you think you may. Again this a personal list i thought I would share, and yes i understand there are 1000000 different ways to put these setups together.
Details about Gen2 3sgte: AFM L-Jetronic engine management ct26 10psi stock boost 12 psi factory fuel cut 8.8 compression ratio 7200rpm redline 430cc injectors metal head gasket TVIS 55mm throttle body inlet valve lift 8.2 fuel pressure 36psi Details about Gen3 3sgte: Bosch D-Jetronic engine management Ct20B MAP Stock boost 13psi Factory fuel cut 18psi 8.5 compression ratio 7700rpm redline Factory 540cc injectors Stainless Steel head gasket TVIS eliminated 60mm throttle body valve lift increased to 8.7 fuel pressure 41psi revised intake manifold Different ECU Bigger bore fuel rail Factory LSD in 80+% of MR2's (E153) Factory catch can Better oil cooler relocated oil filter No 1 Compression ring described as Stainless Steel Slightly more aggressive cams Stock Gen2 Swap Gen2 clip if its an mr2 clip you get the E153 transmission and axles 2200 FMIC and piping 500 Upgraded clutch (optional but recommended) 450 FCD (optional) 50 3" turbo back (optional but recommended) 600 Water/alcohol injection with 6gph nozzle (window washer fluid) (optional) 200 Ecu work 350 Intake (optional) 30 BOV (optional) 200 Boost controller (optional) 100 Walboro fuel pump 100 Gasket, timing belt, water pump, fluids, misc (optional but highly recommended) 500 Swap totals 5280 as stated above with everything included There are short cuts to be had here, based on options and what you might be able to get other parts for. As for clutch and Gasket, timing belt, water pump, fluids, misc, these are not things you want to be fixing when the motor and trans are in the car. Makes life harder, and much more time consuming then when you have the motor sitting on a stand. But its your swap so chose what "optional features/service" you don't wanna do and subtract from price. ***5280-----247whp 260flbs @16psi with 50/50 mix in Water/alcohol injection, with non-LSD*** aka window washer fluid Gen2 performance option 1 CT20B 600 5 Gallons of denatured alcohol 50 SAFC for tunning 200 ***850-----300-310whp with 100% Alcohol injection, with non-LSD*** Gen2 performance option 2 ATS racing 20g rom tune kit (cheaper kits available if less hp is desired) 3100 kit includes: ATS TDO6 20G turbocharger kit ATS 550cc ROM TUNE ATS modified fuel rail flow tested Toyota 550cc fuel injectors (apposed to the stock 440's) walboro fuel pump 170 degree thermostat ***3100-----330-350whp @18psi with 50/50 mix in Water/alcohol injection, with non-LSD*** Gen2 performance option 3 Stand alone---Hydro Nemisis for example starts at 1500 wideband if not bought with ems unit 300 turbo kit of choice 2000 injectors of choice 500 Set of cams, spring, and adjustable cam gears 1000 tunning 800 I understand that you don't need cams....or even an upgraded turbo for that matter to use a stand alone, but i figure if im paying some guy 800 bucks to tune my car.......i don't wanna be calling him back anytime soon bc i didn't need them when the tuner came up. And god knows i wouldn't want to pay an additional 800 just to tune cams, or bigger turbo, or bigger injectors!!!!! This section can vary drastically depending on how extravagant you go. And the number listed below can vary drastically depending on how far you take the motor.....for example head work, built bottom end, etc....at this point you can practically pick the hp you want to run and buy the injectors and turbo to match. If over 400 whp is desired, you may want to start looking into a built bottom end. ***6300-----350whp to limits of stock bottom end (400-450) non-LSD*** Stock Gen3 swap Mr2 clip with LSD E153 (what i prefer) or GT4 clip (cant use transmission) 4000 FMIC and piping 500 Upgraded clutch (optional but recommended) 450 3" turbo back (optional but recommended) 600 Water/alcohol injection with 6gph nozzle (window washer fluid) (optional) 200 Ecu work 350 Intake (optional) 30 BOV (optional) 200 Boost controller (optional) 100 Walboro fuel pump 100 Gasket, timing belt, water pump, fluids, misc (optional but highly recommended) 500 Swap totals 7000 as stated above with everything included There are short cuts to be had here, based on options and what you might be able to get other parts for. As for clutch and Gasket, timing belt, water pump, fluids, misc, these are not things you want to be fixing when the motor and trans are in the car. Makes life harder, and much more time consuming then when you have the motor sitting on a stand. But its your swap so chose what "optional features/service" you don't wanna do and subtract from price. ***7000-----290whp @18psi with 50/50 mix in Water/alcohol injection and LSD*** Gen3 performance option 1 FCD 200 5 gallons of 100% denatured alcohol 50 ***250-----320whp @20psi with 100% Alcohol injection and LSD*** Gen3 performance option 2 TDO6 20g turbo kit from Ats racing (any will do, this is what i like) 2100 5 gallons of denatured alcohol 50 ***2150----363whp @19psi with 100% Alcohol injection and LSD*** Gen3 performance option 3 Stand alone---Hydro Nemisis for example starts at 1500 wideband if not bought with ems unit 300 turbo kit of choice 2000 injectors of choice 500 Set of cams, spring, and adjustable cam gears 1000 tunning 800 I understand that you don't need cams....or even an upgraded turbo for that matter to use a stand alone, but i figure if im paying some guy 800 bucks to tune my car.......i don't wanna be calling him back anytime soon bc i didn't need them when the tuner came up. And god knows i wouldn't want to pay an additional 800 just to tune cams, or bigger turbo, or bigger injectors!!!!! This section can vary drastically depending on how extravagant you go. And the number listed below can vary drastically depending on how far you take the motor.....for example head work, built bottom end, etc....at this point you can practically pick the hp you want to run and buy the injectors and turbo to match. If over 400 whp is desired, you may want to start looking into a built bottom end. ***6300-----350whp to limits of stock bottom end (400-450) with LSD*** additional combinations with prices and whp would be great. Please have some backing behind your numbers.....where i have retrieved all of mine off MR2OC.com. Thanks |
| Lo-Fi Version | Time is now: September 11th, 2026 - 10:34 PM |
