> need help ASAP, car wont start
post Mar 15, 2008 - 11:03 PM
ferngt4
Joined Aug 2, '07
From las vegas
ok so heres my situation, when i was going to work in the morning the car died on me when i made a stop, i thought i let the clutch go and killed it but no so i was like weird so i went on my way. as i kept going the car would loose rpm and shut off but would fire back up. so i made it to work and was going to check it after wards and once i got out the car wouldnt start tried jumoing it and nothing then we found that my wire to the fuse block was garbage so replaced that car started fine didnt bother moving it since i thought that was it so later on in the day im driving and it shuts off again now it wont hold idle and shuts off. now thats every toher try that i do because then it wont even crank or anything. Any idea of what this might be? any help would be great thanks fellow 6gc owners
-Fernando
Replies (1 - 27)
post Mar 17, 2008 - 7:57 PM
pabel89
Joined Sep 28, '07
From new jersey
i would test your altenator.
post Mar 17, 2008 - 9:46 PM
addictions
Joined Sep 26, '07
From iowa
doesn't sound like a motor problem at all. i would say look at your ground from your battery to the frame make sure its not rusty could be the alt. or maybe just replace the battery i would replace the termenals that are on it now with new shinny ones =P lol see if that works at all
-Boss III
post Mar 17, 2008 - 10:54 PM
ferngt4
Joined Aug 2, '07
From las vegas
QUOTE(addictions @ Mar 17, 2008 - 9:46 PM) [snapback]654961[/snapback]
i checked the grounds and they were good. The battery was reading 12.4 volts i think, I had a torn wire from the pos. to the main fuse block i believe. Fixed that and car started then shut off again. The alternator was good also, i also chekced the starter. a friend was telling me it could be the crank postion sensor. what do you guys think? thanks for all the knowledge you guys are spreading to me..
post Mar 20, 2008 - 1:08 AM
ferngt4
Joined Aug 2, '07
From las vegas
so i found what my problem is, well thats what the teacher says it is. it seems to be an ignition module and thats the reason why she is acting up. i went to checkers and they have it but its around 150 and being in school and rent coming up it makes it hard. So my question now is if i can find this at a junk yard or if anyone just happens to be one laying around or knows were i can get it for cheap would help. thanks fellas for all the help
post Mar 20, 2008 - 5:52 AM
pabel89
Joined Sep 28, '07
From new jersey
i would buy it brand new, because you never know if the same problem will show up again in a used one.
post Mar 20, 2008 - 1:15 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
So all you need is the ignitor? The one hung by the fire wall?
I've got two of them. Both from a pick and pull and paid $15 dollars total. Confirm that what you need is an ignitor and I'll ship it out to you. Just pay shipping. And it will be on its way.
94 Celica gt white (sold)
post Mar 20, 2008 - 1:36 PM
D-Man
Joined Jan 18, '08
From Houston
QUOTE(bccentaur3 @ Mar 20, 2008 - 2:15 PM) [snapback]656057[/snapback]
i was going to recomend a scrap yard or craigslist or various other faily cheap websites, but looks like Bccentaur3 has got you hooked up.
2 Woots for Bccentaur3!!
Damn D-Man - most impressive.
post Mar 20, 2008 - 1:44 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Just trying to help a fellow 6gc member. Thats all.
post Mar 20, 2008 - 10:42 PM
ferngt4
Joined Aug 2, '07
From las vegas
QUOTE(bccentaur3 @ Mar 20, 2008 - 1:44 PM) [snapback]656066[/snapback]
yea man thanks. here at uti we have that program we like to call the no data because it dosent have much info but thats the part that it shows on the picture, but this was on the rotor or distributor, ill try taking a picture and pst it so you guys can tell me if thats the one or not. thanks for all the help.
post Mar 20, 2008 - 11:31 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
oh, if its in the distributer thats the ignition coil.
The ignitor itself is on the fire wall.
btw my local toyota dealer qouted me a little over 300 for the ignition coil. so i just bought a new distributor from auto zone.
post Mar 21, 2008 - 4:29 PM
addictions
Joined Sep 26, '07
From iowa
QUOTE(D-Man @ Mar 20, 2008 - 1:36 PM) [snapback]656061[/snapback]
2 more for Bccentaur3!! what a nice guy
-Boss III
post Mar 21, 2008 - 8:27 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Thank you.
So Ferngt4, did you ever find out if it was the ignitor or the ignition coil?
post Mar 21, 2008 - 10:44 PM
ferngt4
Joined Aug 2, '07
From las vegas
QUOTE(bccentaur3 @ Mar 21, 2008 - 8:27 PM) [snapback]656612[/snapback]
Thank you.
yea here at school i looked it up but all that shows up is the ignition module and once i look at the picture it shows the igniter being the piece that went bad
post Mar 21, 2008 - 11:11 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
So did you want me to ship you one?
post Mar 22, 2008 - 6:04 PM
tonytutino
Joined Jun 16, '06
From Bowling Green KY
I'm pretty sure only the GT's have the ignitor on the firewall. have you put your car in diagnostics mode and see if you're throwing any codes? sounds like an ignition problem to me. when my ignition circuit messed up i got a code 14 and needed a new distrbutor
post Mar 23, 2008 - 9:36 AM
ferngt4
Joined Aug 2, '07
From las vegas
how do i put it diagnostics mode? sorry the whole diagnostics thing hasnt really hit me yet, and to think thats pretty much what i do at school..lol
thanks fellas
post Mar 23, 2008 - 3:30 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
So do you still need the ignitor?
post Mar 23, 2008 - 9:32 PM
tonytutino
Joined Jun 16, '06
QUOTE(ferngt4 @ Mar 23, 2008 - 9:36 AM) [snapback]656984[/snapback]
thanks fellas
right by your driverside firewall there is a small little plastic box. thats your diagnostics box. so take a paper clip and stick it in the TE and E1 terminals to make a mini-circuit. theres a label on the inside of the box that has what slot is what, just like your fuse panel covers.
http://www.celicatech.com/imagearchive/bgb...odes%201.8L.pdf
this should help man. but if you need anything more specific then just PM me, i'll help you out!
post Mar 24, 2008 - 11:38 PM
ferngt4
Joined Aug 2, '07
From las vegas
QUOTE(bccentaur3 @ Mar 23, 2008 - 3:30 PM) [snapback]657048[/snapback]
yes i looked at the difference from the st and gt and the only diff. is the location..so to answer your question yea i will need the ignitor. money should be sent if not today tomorrow
post Mar 24, 2008 - 11:43 PM
monkey
Joined Nov 21, '07
From I-59 -N- 610 Houston, Tx
dayum, i love the friendlinesss of this site!
post Mar 25, 2008 - 10:48 PM
ferngt4
Joined Aug 2, '07
From las vegas
yea i love it to..this is officially my new family..lol
post Mar 26, 2008 - 1:42 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
O Fernando, just to let you know I shipped it out. Let me know the results.
post Mar 26, 2008 - 3:31 PM
ferngt4
Joined Aug 2, '07
From las vegas
QUOTE(bccentaur3 @ Mar 26, 2008 - 1:42 AM) [snapback]658071[/snapback]
Alright thanks man, i sent the money yesterday i believe so let me know if you got it. thanks again
post Mar 26, 2008 - 4:02 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Yeah I got the money. Thanks a lot bro.
post Mar 28, 2008 - 12:18 AM
azn87
Joined Aug 2, '06
From bay area
did that fix ur problem? because i kind of got the same thing. my car wont start but everything still works like head lights and radio alarm. etc... let me know thanx
post Mar 28, 2008 - 12:25 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Does it turn over?
post Mar 29, 2008 - 6:35 PM
ferngt4
Joined Aug 2, '07
From las vegas
QUOTE(azn87 @ Mar 28, 2008 - 12:18 AM) [snapback]658999[/snapback]
thats exactly what was going on with mine, it wouldnt turn over or anything but the problem was intermitent and would happen whenever. once i took it to school so i can hook up a scope, i had the teacher look at it and he said i needed an ignition module but nothing showed up under that name only the igniter wich is the piece the teacher pulled out. I let the car sit for about a week and i went and tried starting the car and it worked just fine, hasnt given me any trouble and its been maybe more than a week. so i guess i cant say if it fixed the problem or not because i havent installed the new ignitor, so if you can deal without a car for about a week you can probably try that also.
Lo-Fi Version Time is now: June 10th, 2026 - 1:26 AM
