Aug 28, 2003 - 6:48 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 15, '03 From San Jose, CA, USA Currently Offline Reputation: 1 (100%) |
Well with super's recent problem it is almost a certain fact the stock GT tranny will crush under the pressure, so what options does everyone have? Could everyone please list in possible transmisions that can take the power? include what car they came from, and possibly their designation code. Maybe even list tranies that will bolt but wont last, I'll make a list in this post and keep it updated, maybe worthy of a sticky in this forum. Also include if the tranny comes with a LSD or if its available for it... Thanks.
Ready for the power (this can take almost anything you throw at it) 1. Camry v6/ Solara Code: E-153 2. MR2 Turbo Code: E-153 (used with 3s-gte) LSD included on 94+ Who Knows (bolts to a 3S-GTE, but it could work and it could fail) 1. Celica GT Code: S-54 (used with 5s-fe) 2. Celica SSII/SSIII Code:?? (used with 3s-ge) LSD available AM (this could be a different version of the s54!?) 3. Curren Code: ?? (used with 3s-ge) (this also is a different version of the s54, rumored to be stronger) Cannot be Used (bolts to a 3S-GTE but won't work in a FWD Celica) 1. Altezza Code: ?? (used with 3s-ge) for RWD This post has been edited by Chrobis: Mar 15, 2004 - 1:11 AM |
Aug 28, 2003 - 7:05 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 15, '02 From Corona & Vallejo, CA Currently Offline Reputation: 0 (0%) |
The following trannies will work with a FWD 3S-GTE setup: - Tranny from MR2 Turbo and V6 Camry / Solara <E-153> - Tranny used with the 3S-GE motor <don't not the tranny code> - Tranny used with the 5S-FE <S-54> The only unreliable tranny would be the S-54... I would recommend using the E-153. If the 3S-GE tranny is an E series, then I would recommend that as well. Since I don't know the code... I can't recommend using it at this point, but I know that it will work. As I mentioned in my post in the B&S forum... those that plan on pushing there cars harder than 250+ HP... I would recommend a tranny with LSD... This post has been edited by kuya1284: Aug 28, 2003 - 7:24 PM |
Aug 28, 2003 - 7:12 PM
To elaborate, Celica SS-IIs and SS-IIIs have the 3S-GE, along with some Toyota Currens.
Not any tranny that mounts up to a 3S-GE will work though. For example, an Altezza tranny wouldn't work, because the car is rear wheel drive. -------------------- New Toyota project coming soon...
Aug 28, 2003 - 7:23 PM
It should work Coomer. My E153 is from an MR2 Turbo (RWD), and it works just fine... You did bring up a good point... NOTE: I said *should*, but it would be nice if this could be confirmed. I don't see why it wouldn't work. |
I believe the following will work as well:
A241E => MR2 NA AT S51 => MR2 Turbo AT |
the mr2 tranny need some reworking though right? and if so how much reworking? and I'm guessing the same for the camry tranny?
And what about the ss-II and ss-III , they used the same trannies right? ok on the auto trannies wouldn't you need to change the shifter assembly also, isn't it kinda hard to do that... and whats the point on an auto 3s-gte.... This post has been edited by Chrobis: Aug 28, 2003 - 7:26 PM |
Aug 28, 2003 - 7:30 PM
Sorry for the multiple (quick) posts, but I just found a site with some interesting information. Now if this site is ACCURATE, then I wouldn't trust the tranny that's used with the 3S-GE either. Why? Because apparently, it also uses the S-54 or some other S-series trans.
On to the link: http://www.geocities.com/MotorCity/Pit/997...Transaxles.html Again, I would recommend using an E-series tranny (FWD or RWD, NOT AWD) for high HP applications. Also note that this page doesn't list newer year ranges... So I don't know for certain what trans type the Altezza uses... This post has been edited by kuya1284: Aug 28, 2003 - 7:31 PM |
Aug 28, 2003 - 7:33 PM
There are people that prefer to drive AT rather than MT, which is why I listed those. AT's are just as reliable as MT's, they just aren't as fun to drive... Also... you may want to reference this useful page: http://celica.net/cgi-bin/ultimatebb.cgi?u...c;f=40;t=000028 This post has been edited by kuya1284: Aug 28, 2003 - 7:34 PM |
Aug 28, 2003 - 7:39 PM
SO the "E" series designates more along the lines of a high power, more "racing" aplication tranny?
I guess another question is was the tranny changed with the "BEAMS" series 3s-ge's? And again how much modification was needed on the E-153? Neverstop was saying you have to use the 5s-fe bell housing when using the 3s-ge tranny. Was the same required on the e-153? (I dont know what a bell housing is, enlighten me please) My guess is they probably used a better tranny with the 6th gen 3s-ge's because power output was increased, especially on the beams engines. |
Aug 28, 2003 - 7:50 PM
Yes
That's what I'm trying to figure out... if it was changed, I'm pretty sure Toyota would've used an E-series tranny... but I saw a post with an is300 owner saying he has a S54... it could be that he's not sure of what he's talking about... or they probably do in fact use the S54... Maybe the S54's used with the 3S-GE's are built stronger... dunno...
There was a reason why I posted that link to Celica.net But to add... NO you do not need to change the bell housing with a E153 ... and you may need to use a different speed sensor (i.e. the one that comes with a clip) ... and the axle setup they discussed is different from mine ... I believe those instructions were intended for a 5th gen swap... axles-wise (maybe) ... but overall... it'll still work... The bellhousing is basically the outer shell: bellhousing This post has been edited by kuya1284: Aug 28, 2003 - 7:56 PM |
Aug 28, 2003 - 8:19 PM
does the E-153 come with a LSD? or is it available after market?
Aug 28, 2003 - 8:23 PM
later 94's in the US (I think) and all 94 through 99 JDM come with LSD... Now this is for the MR2T... I'm pretty sure that the Solara's don't have LSD... This post has been edited by kuya1284: Aug 28, 2003 - 8:26 PM |
Aug 28, 2003 - 8:28 PM
Kuya, the tranny your selling is outta an MR2T correct? Now im unsure, and I should look cuz its probably the same in my brothers MR2 N/A, but is the the engine fitted the same as with the Celicas? If not then wouldnt the bellhousing have to be changed?
In addition, if i was to get the E153, why not use the axles from the MR2T, instead of outters from 91 Camry? This post has been edited by Supersprynt: Aug 28, 2003 - 8:33 PM -------------------- |
Aug 28, 2003 - 8:34 PM
Yes, it's out of a 95 JDM MR2T. The NA and Turbo trannies are different... NA = S54 Turbo = E153 Yes, it will fit just fine... My Gen 3 3S-GTE is sitting inside my engine bay with an E-153 (with LSD) bolted... the bellhousing was not changed... my current dilemna is having to buy LSD inner axle shafts... which costed me $400 for the pair... I just have to wait for those to come in... then I'll be boostin... The inner half-shafts need to be MR2T axles (LSD or non-LSD type, depending if you decide to install the LSD)... With my application, I'm using 88-91 V6 Camry outter half-shafts to make this work... you cannot use the full MR2T axles because 1. They're too short 2. The outter shaft will not connect to your hub (as I understand it) This post has been edited by kuya1284: Aug 28, 2003 - 8:37 PM |
Aug 28, 2003 - 8:42 PM
so if you get a different tranny, what needs to be replaced? Bellhousing stays the same, but whats this about the axcels and half shafts and such?
Aug 28, 2003 - 9:06 PM
What I may want to do is get the E153 but wait on the LSD for now because i'll only be pushing 240hp and I dont have the cash. To my understanding that tranny will work with the MR2T transaxles, or am I confused...again.
We shoulda gotten a chatroom for this topic This post has been edited by Supersprynt: Aug 28, 2003 - 9:07 PM -------------------- |
Aug 28, 2003 - 10:01 PM
Good point Ray...I didn't think of that. -------------------- New Toyota project coming soon...
Aug 28, 2003 - 11:51 PM
Everything regarding the E153 into a FWD swap is all pretty much covered in the link I posted...
The following image should give a better explanation of the axles: ![]() Super, now in your case, if you just get the tranny with no LSD, then you can use the standard MR2T inner shafts. But if later you decide to go with LSD, you'll need the MR2T inner shafts that's designed for LSD. But this is only if you go with the factory LSD. If you go with a Quaif or Kaaz LSD, I believe the make an application that will work with the standard MR2T inner shafts. I hope this clears things up for you guys. |
Aug 29, 2003 - 1:45 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Anaheim, CA Currently Offline Reputation: 0 (0%) |
hu, didnt know that the mr2-T had the option of an auto tranny -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
Aug 29, 2003 - 2:24 AM
Yeah... I didn't think so either... I could be misinterpreting what I read... my bad if I did... I coulda sworn that the Toyota AT trannies began with an A. So I could be wrong here. |
Aug 29, 2003 - 7:12 PM
So I still wouldnt be able to use the entire MR2T transaxles, just the innershafts with the stock outter
Sep 2, 2003 - 3:10 AM
Enthusiast ![]() ![]() ![]() Joined May 1, '03 From Michigan Currently Offline Reputation: 0 (0%) |
The 3SGE Curren and SSII / SSIII Celica's came with the S54 trans. It rumored that the gear ratio was revised, but most of the internals are the same as the S54 on the GT Celica's.
On that note, who is saying the S54 trans is weak? Ryan's T67 powered 3SGTE 6th gen put down over 500HP on the dyno at CJ Motorsports using the stock S54 trans! There are 3 companies that make a LSD unit for the S54 as well. The only advantage of the E series trans is the gear ratio - which is better for top end and cruising. The S54 has a higher ratio, making it better for drag. -------------------- Scott
West Michigan |
Sep 2, 2003 - 12:50 PM
Scott: I'm saying that it's weak... I've seen many instance where this tranny blew up... Super is one example, Clayton on Celica.net another, and other people you all aren't familiar with here in Cali. The only time I've heard of the S54 withstanding the torque of a 3S-GTE is with that Ryan dude... and the only way that I can see a S54 lasting is if it's brand spanking new, or rebuilt... |
This topic was started due to the fact that my tranny blew itself a new asshole 3 days after I got the 3sgte on the road. Now, I have heard that GT with 500+hp but how much mileage does it have? I had 185,000. Thats alot of mileage for just stock engine and pretty impressive i think. And it wasnt the gears the blew out, it was the bellhousing.
Mar 9, 2004 - 10:55 PM
![]() Enthusiast ![]() Joined Jun 30, '03 From Columbus, Georgia Currently Offline Reputation: 0 (0%) |
so could you not go to car-part.com and get the mr2 tranny as well? and couldnt you go to autozone to get axles? or would it generally be more expensive?
Mar 10, 2004 - 11:50 AM
Enthusiast ![]() ![]() Joined May 8, '03 From San Jose, CA Currently Offline Reputation: 0 (0%) |
There was a celica 5sfe turbo florida that was doing 380 whp with stock tranny. I think he since switched to a camry tranny but only to get his top speed up. never had any problems with the stock one, just kept good gear oil in it and shifted smooth and it was fine.
remember too: people blow these trannies up all the time on STOCK celicas too. It's called bad driving and clashing gears or beating on it in general. I'll probably blow mine up soon too...but so far I'm at about 1500 miles with the swap and still doing ok. - aba |
Mar 10, 2004 - 12:22 PM
W00t for topic resurection...
Mainly what has been said a million times is a GT tranny (s54) can be used, sometimes its good, sometimes its not. But mainly its generaly safer to go with the MR2/camry v6 tranny. |
Mar 10, 2004 - 1:12 PM
Heres the deal with mine, i didnt blow the tranny i blew the bellhousing. There was improper stress placed upon it and it blew a hole. The actual gears are ok although the synchros are going. But they were going before i did the swap. I've done 5,000 miles not going over 4K rpm and 90mph and its been ok. Only time will tell....just be gentle on it.
Mar 15, 2004 - 12:59 AM
nothing.
This post has been edited by Chrobis: Mar 15, 2004 - 1:16 AM |
Mar 15, 2004 - 8:20 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 3, '02 From Va Team 6gc Currently Offline Reputation: 1 (100%) |
so, is there a automatic tranny that will work(can anyone confirm kuya's auto mr2)?
-------------------- ![]() All I have in this world is my Balls and my Word and I'm not breaking em for no one,- Tony Montana Team 6gc 2005 |
Mar 15, 2004 - 10:22 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jun 10, '03 From FL Currently Offline Reputation: 0 (0%) |
so ive read thru this many times, and i am still lost. Its obvious that you cant use the mr2t transmission because it is two short as kuya has stated. So does that mean that you could use the e series 6cyl camry transmission by itself and be safe? Now what Kuya was talking about on mixing the two was so that he could have the limited slip of the mr2 mixed with teh correct size of the camry. I am not to worried about the lsd right now, i just want the e series tranny so that it can be replaced while the engine is out of the car. So to sum my question up, can the camry 6 cyl mt be used w/o the mr2t parts?
Mar 15, 2004 - 11:12 PM
You can use the E series trans from the MR2 Turbo or Camry, or the S series trans from the 5F powered cars.
West Michigan |
Mar 15, 2004 - 11:15 PM
this might be a stupid question but why cant you use the jdm tranny that comes with the motor??
Mar 15, 2004 - 11:38 PM
awd. celli is fwd |
Mar 15, 2004 - 11:41 PM
i know that
Mar 16, 2004 - 2:29 AM
the transfer box or whatever would be in the way i believe, amongst other things.
and to blkgt, the mr2 tranny can be used. I dont know what your saying about it being to small, all you need to do is use the different axcels, half the axcels from the mr2, and half the axcels from the camry. |
Mar 16, 2004 - 9:24 PM
And I have pictures of the axles that I used in my project diary. Just go to the Completed Engine Swaps sticky... |
Mar 18, 2004 - 8:13 PM
Have you ever even seen an AWD transmission?? im guessing on no. |
Mar 18, 2004 - 9:02 PM
i havn't seen an awd tranny thats why i ask the question I always see guys talking about the mr2 turbo tranny or the v6 camry tranny i just wanted to know if anyone stuck with the origenal gt4 tranny
Mar 18, 2004 - 9:46 PM
Enthusiast ![]() Joined Feb 21, '04 From Oklahoma Currently Offline Reputation: 0 (0%) |
My head hurts.
Mar 18, 2004 - 9:47 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 25, '04 From Wisconsin Currently Offline Reputation: 0 (0%) |
nik,
From my understanding of AWD and FWD, owning both of the same car, the AWD loses roughly 1/4 HP in transferring the power to the rear wheels. I believe you can hook up the AWD tranny to car, however you'd lose tremdious power going to nothing... and what good is that. However, I dont even know if theres room for the AWD tranny on the FWD body. Then again... make it really easy. Import a GT4, switch VIN plates, tint your windows really really dark and have fun for at least a week. Its a whole lot easier than all this swap stuff. lol. And for all you over-thinkers... dont take this serious. |
Mar 18, 2004 - 9:56 PM
thanks for explaining it that helps
Mar 31, 2004 - 10:07 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
Woa woa woa. I've been lurking here for a long time, but when I saw something so horribly blatantly wrong, I just had to register and correct it. Think about this for a second. FF = Transverse mounted engine and tranny, drives the front wheels sitting under the engine MR = Transverse mounted engine and tranny, drives the rear wheels sitting under the engine FR = Longitudal mounted engine and tranny, drives rear wheels with a driveshaft running from the front to the back of the car. TOTALLY DIFFERENT TRANSMISSION!!! An MR tranny is the exact same as a FF tranny, but a FR tranny... no. The FR tranny only has a place for one large driveshaft, the FF and MR have places for two halfshafts. BTW: FF = Front engine front wheels FR = Front engine rear wheels MR = Mid engine rear wheels -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Mar 31, 2004 - 12:23 PM
Yeah, the same... but the forks will sit on opposite sides. - aba This post has been edited by abatardi: Mar 31, 2004 - 12:25 PM |
Mar 31, 2004 - 12:54 PM
Thanks for the confirmation. |
Mar 31, 2004 - 1:13 PM
yeh i thought this was clear already... |
Mar 31, 2004 - 1:18 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 4, '02 From Davenport Iowa Currently Offline Reputation: 0 (0%) |
Not dissagreeing with you but I have a JDM 93 3s-ge trans and to use it on a 3sgte I would have to swap the bell housing off a 5sfe trans... Reason being is that the starter is located in the wrong position. the start exits out towards the exhaust manifold instead of away from it as the 5sfe, 3sgte and later model 3s-ge transmissions. as it sits right now it would hit the lower half of the turbo. I can post pics of it to further show this as for fitting the 3sgte tranny into the US spec 6GC it will fit just fine (somone posted about this on the last page).. the problem with just putting it in there and not hookin up there rear is that the transfer case will just sit and spin while your car goes nowhere edit: let me explain a little better... the car will move but not very fast and you will lose alot of your power as the transmission will try and send the power from the motor to the point of least resisitance.. the transfercase with nothing hooked up to it.. I tried this just to see what would happen.. I also tried welding in a bar to lock the transfer case and that worked for but only for a short time until that broke, think I got around the block a couple of times before it started to flex to the point where it busted This post has been edited by NEVERSTOP: Mar 31, 2004 - 1:24 PM -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
Apr 1, 2004 - 2:47 AM
Enthusiast ![]() ![]() ![]() Joined Apr 29, '03 From Davenport, IA Currently Offline Reputation: 0 (0%) |
Hmmm but from looking at my 3sge tranny, it seems that it might fit perfectly on my st185 engine. I have never put it up against it and tried but.....thats what I'm guessing. NEVERSTOP, call me in the morning and get your ass over here for a few minutes and check it out with me. If it won't fit, sh3t, I'll just sell it and get a MR2 w/LSD. |
Apr 5, 2004 - 11:36 PM
ok ok , so i cant just use a straight 6cyl camry transmission. I MUST mate it with the mr2. plus that gives me the limited slip option?
Itd be so much nicer if the camry would just work by itself |
Jun 30, 2004 - 3:06 PM
Enthusiast ![]() ![]() Joined Jun 27, '04 From ohio Currently Offline Reputation: 7 (100%) |
I have heard that you can use the gt4 trany and make it fwd by removing the rear output shaft and making an cover to seal it up is this recomended?
Jun 30, 2004 - 4:22 PM
no thats not a very good idea.
Jun 30, 2004 - 5:06 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '04 From Illinois Currently Offline Reputation: 0 (0%) |
Read NEVERSTOP's post in this thread. It makes sense why using the AWD tranny is not a good idea.
-------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
May 4, 2006 - 7:29 AM
Enthusiast Joined Oct 7, '04 From Finland Currently Offline Reputation: 0 (0%) |
Hi.
I have ST202 celica 3S-GE with 129kw. I need new gearbox. My old ones code is E56, wtf is that ? and which transmissions are compatible with this one ? My car is from Germany and im living in Finland. Thanks. |
May 4, 2006 - 7:37 AM
Enthusiast ![]() ![]() ![]() Joined Feb 15, '05 From Frederick, Maryland Currently Offline Reputation: 8 (75%) |
what,.... i am using an awd tranny and it makes perfect sense
This post has been edited by yungazzdriver: May 4, 2006 - 7:38 AM |
May 4, 2006 - 2:17 PM
Enthusiast ![]() ![]() Joined Dec 8, '04 Currently Offline Reputation: 0 (0%) |
QUOTE(Belhan @ May 4, 2006 - 7:29 AM) [snapback]429964[/snapback] Hi. I have ST202 celica 3S-GE with 129kw. I need new gearbox. My old ones code is E56, wtf is that ? and which transmissions are compatible with this one ? My car is from Germany and im living in Finland. Thanks. Where you get that code from? All ST202's came with S-54 trannies. Just look for another Celica with a 3S-GE and take the tranny off of that. |
May 4, 2006 - 3:38 PM
QUOTE(BLADDER_MASTER @ May 4, 2006 - 7:17 PM) [snapback]430126[/snapback] QUOTE(Belhan @ May 4, 2006 - 7:29 AM) [snapback]429964[/snapback] Hi. I have ST202 celica 3S-GE with 129kw. I need new gearbox. My old ones code is E56, wtf is that ? and which transmissions are compatible with this one ? My car is from Germany and im living in Finland. Thanks. Where you get that code from? All ST202's came with S-54 trannies. Just look for another Celica with a 3S-GE and take the tranny off of that. I found it from that plate where is written all information about ur car, like chassis code and stuff.(i dont know whats the right name in english) Anyway its under the hood Anyway i catch one tranny from finland which got about 40000miles on it. It costs 600$. Much cheaper than repair the old one |
| Lo-Fi Version | Time is now: August 4th, 2026 - 11:12 AM |
