Mar 19, 2008 - 8:26 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 26, '07 From riverside,CA Currently Offline Reputation: 0 (0%) |
does anyone know all the tools required to remove the axel so me and a couple buddies can replace it with a new one?
-------------------- QUOTE(thespacepanda @ Feb 21, 2008 - 4:37 PM) [snapback]644164[/snapback] When I worked for Pizza Hut our store won a health code violation. |
Mar 19, 2008 - 8:40 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) |
ratchet 3/8"
breaker bars - 3/8" 1/2" vice grip 10mm-19mm socket set & wrenches 24mm or 30mm axle nut forgot which it is new cotter pin hammer to get steering tie rod end off. crow bar/pry bar ___________________________ ^^ usually what i have handy. hardest part is the axle nut. |
Mar 19, 2008 - 8:45 PM
you know the process of taking it out right?
Mar 19, 2008 - 8:48 PM
well not my personally... i think he has some bit of knowledge... but if you would kindly put down the details it be nice :]
Mar 19, 2008 - 8:53 PM
AH HA! stickies.
http://www.6gc.net/forums/index.php?showtopic=49331 replacing front wheel bearing tells you everything! only difference is that you're removing the axle from the transmission - make sure to drain it first. |
Mar 19, 2008 - 9:04 PM
okie that confused me a bit ahaha
Mar 19, 2008 - 9:11 PM
why confused?
Mar 19, 2008 - 9:15 PM
maybe i didnt read it right but i didnt see any part about the axel >.<
Mar 19, 2008 - 9:52 PM
QUOTE(hongkongnerdboy @ Mar 19, 2008 - 9:15 PM) [snapback]655802[/snapback] maybe i didnt read it right but i didnt see any part about the axel >.< just do what it says, and when the axle is free, pull it out with a pry bar and put the new axle in. http://www.celicatech.com/imagearchive/bgb...afts%201.8L.pdf http://www.celicatech.com/imagearchive/bgb...afts%202.2L.pdf |
| Lo-Fi Version | Time is now: August 2nd, 2026 - 10:52 AM |
