> Speedo Stopped Working, Help!?
post Mar 21, 2008 - 6:33 PM
94celicadude
Joined Mar 28, '04
From St.Louis
I washed my car yesterday because it was nice and warm,
and after washing it i noticed that the speedometer stopped working, it just sits and reds 0 MPH all the time, the rest of the gauges work perfectly, and i have checked my wires that go to the speed sensor on the outside top side of the gearbox, even cleaned the contacts to see if that was it, still nothing.
has anybody had this problem before?
1994 GT Hatchback
1994 ST Coupe
1988 Corolla Wagon All-Trac
1999 Corvette
2008 Cobalt SS Turbo
Replies (1 - 7)
post Mar 22, 2008 - 5:07 PM
94celicadude
Joined Mar 28, '04
From St.Louis
has any one at all had a problem with their speedometer going out? and if so, how did you fix it?
1994 GT Hatchback
1994 ST Coupe
1999 Corvette
post Apr 14, 2008 - 6:41 PM
heinzi98
Joined Nov 5, '07
From westminster md
I've been screwing around with mine for some time. Harness shorted at back of instrument cluster. Instrument cluster needs replacing and I still haven't found the male connector I need. Toyota dealer will sell me nothing less than the ENTIRE dash wire harness. Hope your solution is easier. The only way to access unit is by dropping steering column.
heinzi98
post Apr 14, 2008 - 7:05 PM
Do you have overlay gauges on your cluster? If you dont glue them down correctly they can kill your cluster.
post Apr 16, 2008 - 8:06 AM
dabazied
Joined Jun 10, '07
From Riverside, CA
Start jiggling the wires behind your gauges(i think the one for the speedo is in the connector to the far left if you are looking at your gauges from the front) one by one. You'll find out which one it is, then whallah, do some fixin.
She's Alive...... Again!!!
Sweet Jesus.
You rang?
Sorry, wrong number. :laugh:
post Apr 16, 2008 - 10:37 AM
D-Man
Joined Jan 18, '08
From Houston
Fuse? i'm not in my pannel right now, but i used to have an old cougar that did that, and it actualy had a fuse go out. It was connected to that and a few other system items... Maybe.
But that was not a 6g, and i'm not in my car righ tnow so~
Damn D-Man - most impressive.
post Apr 16, 2008 - 11:14 AM
DEATH
Joined Dec 19, '07
From tx
QUOTE(dabazied @ Apr 16, 2008 - 8:06 AM) [snapback]665063[/snapback]
Good idea but the problem with this idea is that he's going to have to be doing at least 5mph in order to see any fluctuations wink.gif
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Apr 16, 2008 - 11:44 AM
D-Man
Joined Jan 18, '08
From Houston
QUOTE(DEATH @ Apr 16, 2008 - 11:14 AM) [snapback]665115[/snapback]
but it's so true~
Lo-Fi Version Time is now: June 14th, 2026 - 4:51 PM
