> what are your opinions on this kit?
post Mar 31, 2008 - 11:45 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Toyota 2164cc 16V DOHC Celica (90-00), MR2 (90-95)
Engine
Code Stock
Bore Includes: Engine Kit #/Price
5SFE 87mm Complete Gasket Set
Cometic Head Gasket
ROSS/Wiseco Forged Pistons
(87, 87.5, 88mm bore) and
(8.5-1, 9.5-1, 10-1, 11-1 comp ratio)
Performance Rings
Performance Wrist Pins
TOGA HP Main Bearings
TOGA HP Rod Bearings
Thrust Washers
Timing Belt
Expansion Plugs EKTO25MPX
$899
Following Kits w/TOGA HV Oil Pump
EKTO25MPXG
$995
I was just curious, because I was planning on replacing a few internal parts, just to be safe.
94 Celica gt white (sold)
Replies (1 - 8)
post Apr 1, 2008 - 12:01 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Might I add the cosmetic head gasket will obviuosly not be used with my app.
post Apr 1, 2008 - 1:05 PM
alltracman78
Joined Aug 9, '06
From Ma
Sounds decent. :shrug:
I wouldn't worry about the oil pump, unless yours is specifically having problems, they VERY rarely go bad.
Why aren't you going to use the MHG?
And what's your "app" [other than stock 5SFE?].
post Apr 1, 2008 - 3:56 PM
6strngs
Joined May 12, '06
From Wilmington, NC
you can get all that for $899?!?! I thought pistons alone for the 5sfe were like $600.
I dunno how much boost/horsepower 5sfe rods are good for, but since you have the engine taken apart, you might as well throw some in.
post Apr 1, 2008 - 6:35 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Thats what I was sayiing too. Hold on is the Cometic HG the same thing as a Metal HG? If so I wouldn't need to go out and buy the other HG then. But to be honest this deal looks good.
post Apr 1, 2008 - 6:51 PM
6strngs
Joined May 12, '06
From Wilmington, NC
where are you getting this kit?
post Apr 1, 2008 - 6:52 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Let me post the link hommie. hold on tight.
post Apr 1, 2008 - 6:57 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
scroll down to #15 click
post Apr 1, 2008 - 9:06 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
dang pretty good price for all that good find!
Lo-Fi Version Time is now: August 24th, 2026 - 12:05 PM
