Apr 24, 2008 - 3:18 AM
Enthusiast ![]() ![]() Joined Jul 21, '04 From Fresno, CA Currently Offline Reputation: 1 (100%) |
Hey guys.. I remember a while back a few of you guys were putting on the 7th gen short shifter into your cars. There were some modifications you had to do and i remember there was a how to (I think) but i can't seem to find it anywhere. If you guys have the info let me know. thanx
Apr 24, 2008 - 3:23 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 8, '05 From torrance/carson, ca Currently Offline Reputation: 11 (100%) |
http://members.cox.net/newportspeed722/199...on%20Manual.pdf
also in step 6, it says you don't need to worry about breaking the clip... well you need that clip. i almost threw mine away. and you also have to put spacers under the assembly. other than that, just follow directions. This post has been edited by j0e_p3t: Apr 24, 2008 - 3:27 AM -------------------- |
Apr 24, 2008 - 11:42 AM
Thats for a TMW short shifter... Im talking about the one from the 7th gen celica... I remember you had to use a dremel to grind somewhere but can't remember where, its been a while back when someone did this.
Apr 24, 2008 - 2:35 PM
QUOTE(blackbullet @ Apr 24, 2008 - 12:42 PM) [snapback]667688[/snapback] Thats for a TMW short shifter... Im talking about the one from the 7th gen celica... I remember you had to use a dremel to grind somewhere but can't remember where, its been a while back when someone did this. i did not dremel anything. what i did is instead of using the spacers they gave me, i used 4 washers in each bolt. Check the stickies too in the electrical section. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Apr 24, 2008 - 2:57 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 14, '07 From Provo, UT USA Currently Offline Reputation: 25 (100%) |
i didn't need to modify anything on mine either. no rubbing at all.
Apr 24, 2008 - 3:07 PM
I went about not using the spacers. Does it prevent the stick from being notchy during shifts? I just figured it wasn't a big deal if I went without the spacers. I guess I will put them in and see what the differences are.
Apr 24, 2008 - 5:02 PM
QUOTE(blackbullet @ Apr 24, 2008 - 9:42 AM) [snapback]667688[/snapback] Thats for a TMW short shifter... Im talking about the one from the 7th gen celica... I remember you had to use a dremel to grind somewhere but can't remember where, its been a while back when someone did this. same exact directions i used for my 7gc ss. -------------------- |
Apr 25, 2008 - 1:06 AM
Thanks alot guys... i found it in the electronic tread... thanks
Apr 25, 2008 - 7:42 PM
QUOTE(blackbullet @ Apr 25, 2008 - 2:06 AM) [snapback]667957[/snapback] Thanks alot guys... i found it in the electronic tread... thanks this is what i talked about, used washers instead of the spacers. but its your option
| Lo-Fi Version | Time is now: September 2nd, 2026 - 1:51 AM |
