May 5, 2008 - 12:55 AM
Enthusiast Joined Jan 18, '08 From texas Currently Offline Reputation: 0 (0%) |
i know its the simplest swap but
wat kinda problems can i run into and were can i get a damn 5sfe i been lookign for one for a long time |
May 5, 2008 - 1:18 AM
Enthusiast ![]() ![]() ![]() Joined Sep 28, '07 From Toronto, ON Currently Offline Reputation: 5 (100%) |
no engine swap a simple swap, it always takes time also you need a new tranny with that too....
tigerjapanese.com that's a pretty good site, but you still need the wiring... |
May 6, 2008 - 7:23 AM
Enthusiast Joined Apr 30, '08 From new hampshire Currently Offline Reputation: 0 (0%) |
yeah... i was thinking about doing this swap, i thought it was a simple swap too, but i found out otherwise, all the wiring is different, your A/C lines dont hook up, you need to re-do all your wiring pretty much... if you still want to do it, i have a 93 gts with a 5sfe and tranny runs and drives great, but i dont suggest swapping to a 5sfe
May 6, 2008 - 7:38 AM
silvertop is better.
May 8, 2008 - 10:35 PM
Enthusiast Joined Feb 5, '08 From Pittsburgh,PA( New Kensington) Currently Offline Reputation: 0 (0%) |
its actually not that hard. you'll need : from a GT or 5SFE with transmission....ECU,Engine Harness,Power steering lines,axles,shift linkage. if i think of some other parts i'll let you know.....simply unlug the ecu. the thru way is top left of engine bay. pull the wire back through to the motor. the motor will come out with all wires,pwr str.excc.... attached....the rear motor mount is in a crap spot. but with the right tools it wasn't hard. the power steering line is different, the one that attaches to the pump. different bend at the end. and you will need a 5SFE radiator, a/c condensor and lines. the left motor mount is the only one that bolts differently. i welded mine to the engine bay. but you can see where the bolt would go for a GT. has an indentation like a covered hole. you could drill and tap it. thats just off the top of my head. i did it in mine. and it was SOOO worth it. i have a 25th anniversary. it was nice being rare. but not slow. i'm def happy with it now. let me know if you decide to go head with it. i can guide you through. i baught a whole other celica and swapped mine out. so i had all the parts readily available. i also got the bigger front brakes and rear disc!
-------------------- I Drive One of a Kind's
| Lo-Fi Version | Time is now: September 2nd, 2026 - 1:02 AM |
