> Whats missing, find x in the equation.
post Sep 3, 2003 - 11:17 PM
5sfeTurbo
Joined Apr 14, '03
So I have enough cash now to throw around. Starting with
Web-Cam hardweld
Ross Pistons and Rods (if someone would answer my thread about its fit)
Apex SafcII (give it a good tune)
CraneCam HIR-6TI (i think thats the model#)
MSD Coil
Nology Wires (i guess my NGK's wont due)
Along w/ my basic intake/exhaust, pulley and plugs.
Pesonally I like N/A Im not looking for a turbo charged monster I know the 3sgte is the ultimate swap but I starting to respect my 5sfe the more posts i read on the MR2 boards. I want an all N/A celica that will be alot more zippier and respectable. So if you can tell me what you think you would do add or subtract to the list above.
Remember..I want N/A not a 3sgte.
Replies (1 - 21)
post Sep 4, 2003 - 1:22 AM
Also, I'd consider a lightweight flywheel. I was talking to Neipas09, and he said he felt a very nice gain in acceleration after installation of his new clutch and flywheel. smile.gif
post Sep 4, 2003 - 1:45 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
well since you have an auto, i suggest doing some work to that.
get a performance TC and a shift kit. a performance TC in general shaves about 1/2 a second of of your ET and makes response better all around. the shift kit makes the tranny shift as fast, if not faster than a 5spd with out missshifts.
if you have $3k o spend on just the tranny, you could get a fully rebuilt performance tranny for your car from www.levelten.com.
bore out you throttle body and get larger injectors, custom intake manifold, replace you valve springs, port and polish, raise the CR, upgrade the fuel pump, performance FPR, oil cooler, tranny cooler
just throwing out some ideas
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Sep 4, 2003 - 1:57 AM
post Sep 4, 2003 - 2:41 AM
1bwilson
Joined Aug 30, '02
From Maryland
For the intake manifold you can use a JDM 3sfe one. Its a direct bolt on and with a 60mm TB its been said to get gains around 40hp on the mr2. You will need some bigger injectors (supra N/A 7mge ones will do) and if I were you I would also go with a complete stand alone EMS. You said you've been reading up on the mr2 boards so Im sure you realized that but most all the hardballers over there have one and sware that tuning the 5sfe is the key.
-Bryan-
Member of Team 5sfTe
post Sep 4, 2003 - 7:14 AM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
you also might want some cam gears, headers, you could instead of getting a new manifold and boring out your throttle body get the intake manifold ported and throttle body ported to your manifold. i would suggest look to your cooling system as well ie. a new 3 row aluminum radiator. if your looking to make a outright n/a racing machine remove your power steering pump, and for thouse days at the track have a smaller belt that you can use to take your altenator outta the equasion, thus eleminating drag on your crank..... just remeber to charge your batery first haha....... thats all i have for you right now, ill be back with more later
post Sep 4, 2003 - 12:24 PM
Junior
Joined May 5, '03
From Toronto
If you're going N/A, I would probably put off the pistons and rods. Get your motor compression tested, if it is way off, do the pistons and rods. If not, spend the money on head work, ie. port and polish, port match. A $20 test can save you hundreds.
post Sep 4, 2003 - 2:23 PM
1bwilson
Joined Aug 30, '02
From Maryland
QUOTE (thedevilmaycrie @ Sep 4, 2003 - 5:14 AM)
you also might want some cam gears, headers.
The 5sfe only has 1 cam gear. The exhaust cam is a slave to the intake cam. I havent seen any cam gears for the 5sfe but I am like 75% sure a HKS one for the 3sgte will work. Also you will need only 1 header for the 5s.
-Bryan-
post Sep 4, 2003 - 3:33 PM
macavely
Joined Nov 4, '02
well if you have money to throw around you should do something most poeple don't think about...you should retune you transmission... whats the point of having a zippy N/A car.. but your transmission doesn't let you show off the power that engine trully has..
post Sep 4, 2003 - 3:56 PM
QUOTE (macavely @ Sep 4, 2003 - 12:33 PM)
Do you mean getting new gears with different ratios and an LSD?
post Sep 4, 2003 - 10:27 PM
Phr0z3n664
Joined Oct 20, '02
From Covington, La
what car and year for the JDM 3SFE Intake manifold are the ones to look out for?
post Sep 4, 2003 - 10:41 PM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
Yeah, ive never heard of putting a 3SFE intake manifold in place before....but im really interested now. smile.gif Im imagining putting in the 60mm intake manifold, 7MGE injectors, and a performance flywheel and clutch....from the sounds of it you could free up a decet ammount of power by doing soemthing like that.
So by swapping the 5SFE manifold for a 3SFE manifold, you could get gains of somewhere around 40 horsepower tops without any other tuning like SAFC, etc.??
post Sep 4, 2003 - 11:23 PM
macavely
Joined Nov 4, '02
QUOTE (Coomer @ Sep 4, 2003 - 3:56 PM)
yea thats exactly what i mean
post Sep 4, 2003 - 11:50 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
coomers right about the tranny and flywheel..... you can put all the power into the engone that you want but if you can use it whats the purpose of using it........ ummm a few more ideas are to reduce wieght whenever possible.... i believe , correct em if im wrong but for every 7 bls you loose you gain like one hp... anyone know for sure?
post Sep 5, 2003 - 1:38 AM
1bwilson
Joined Aug 30, '02
From Maryland
QUOTE (Silver94CelicaOwner @ Sep 4, 2003 - 8:41 PM)
Theres only 1 jdm 3sfe engine. Also you can use the cams for about 6k instead of the 5800 that the 5sfe ones get.
-Bryan-
post Sep 5, 2003 - 7:53 AM
Phr0z3n664
Joined Oct 20, '02
From Covington, La
You talking about rpm 1bwilson?
post Sep 5, 2003 - 11:11 AM
QUOTE (thedevilmaycrie @ Sep 4, 2003 - 8:50 PM)
You don't actually gain horsepower from reducing weight, just like you don't gain horsepower from a lightweight flywheel. You'll be able to accelerate faster though with less weight, because the engine uses the same amount of horsepower to move less weight. wink.gif
post Sep 5, 2003 - 3:15 PM
5sfeTurbo
Joined Apr 14, '03
97sccelica what is a TC amd a shift kit?
post Sep 5, 2003 - 4:23 PM
1bwilson
Joined Aug 30, '02
From Maryland
QUOTE (Phr0z3n664 @ Sep 5, 2003 - 5:53 AM)
Sorry...... Yes.
-Bryan-
post Sep 5, 2003 - 4:54 PM
5sfeTurbo
Joined Apr 14, '03
never mind I got 97scc. lol . wow that shift kit seems more that worth it. So how about the TC that you send in to be beffed up, which is have the price of the performance one, would that be about the same or just go all the way.?
post Sep 5, 2003 - 6:17 PM
5sfeTurbo
Joined Apr 14, '03
Hey guys isnt a TC like a lightweight flywheel for a manual. Basically putting more HP on the road?
post Sep 6, 2003 - 2:01 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (5sfeTurbo @ Sep 5, 2003 - 4:17 PM)
torque converter
its what makes auto tranny's possible. auto tranny's tend to be less efficient because the tranny gears are not actually attached to the engine, like the clutch in a 5spd tranny.
instead it works off of fluid. a performance TC is made to be more efficient in putting the power into the tranny, which helps put more to the wheels and give a quicker response, similar to a flywheel and clucth upgrade on a 5spd car.
Lo-Fi Version Time is now: September 3rd, 2026 - 10:36 PM
