May 12, 2008 - 4:41 PM
Enthusiast ![]() Joined Jun 3, '06 Currently Offline Reputation: 0 (0%) |
When i changed my oil the last time i overfilled it by about half a quart, this happend because much to my rage i spilled some so i overcompensated too much when i tried to put in a little over 4 quarts. The engine has been run for a few weeks like this, yesterday while the engine was warmed up i checked my oil and was shocked at how overfilled it was, i was wondering will this hurt anything? Thanks for the help
May 12, 2008 - 5:41 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jan 25, '06 From MN Currently Offline Reputation: 19 (100%) |
If you overfilled (depends how much) your motor with oil my advice to you is drain it and start over again it. Yes is can cause engine damage when you overfill the crankcase with oil, it'll foam up and cause problems like throw a rod through your block or worse a seized motor.
-------------------- "To Protect And To Serve The Wealthy" -POLICE
May 12, 2008 - 5:55 PM
^ I totally agree. You could do irreparable damage by running your engine with too much oil in it. Drain some of it out before you screw up your gaskets/valve seals/whatever it is that gets ruined by this (I forget, but I know it's not good).
May 12, 2008 - 6:50 PM
Enthusiast ![]() Joined May 8, '08 From Marietta, Ga Currently Offline Reputation: 0 (0%) |
it may be tedious, but just drain a little bit out, check it again, and repeat until it is filled to the full line.
May 12, 2008 - 7:05 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 29, '07 From Philly Currently Offline Reputation: 11 (100%) |
it may be tedious, but just drain a little bit out, check it again, and repeat until it is filled to the full line. x2 -------------------- ![]() I"M NOT A TOYOTA FAN, IM A FANATIC 1984 accord hatch 5 speed (T-Belt)-Junkyard 1991 VDUB jetta wolfsburg Ed. 5 speed (clutch)-junkyard 1988 Dodge Aries K (sold) 1969 Chevy El camino - Traded for celica 1991 Dodge Daytona-Traded for Celica 1988 Chevy Camaro-Work in Progress 1989 Ford Mustang LX 5.0 - For Sale 1995 Toyota Celica-Work in Progress |
May 12, 2008 - 7:10 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 15, '07 From Fort Worth, TX Currently Offline Reputation: 12 (100%) |
It is actually ok to be up to a quart over. It is recommended, especially when you take many sharp turns.
-Matt |
May 12, 2008 - 8:28 PM
alright guys thanks for all the replies, so is half a quart (roughly) over enough to do all that? If it is ill drain it alittle tommrow shouldnt be too big of a deal
May 12, 2008 - 8:59 PM
alright guys thanks for all the replies, so is half a quart (roughly) over enough to do all that? If it is ill drain it alittle tommrow shouldnt be too big of a deal It'll be worse if you have a high mileage engine as all the seals are probably worn if not leaking already. My oil is always at 3/4 you never want too low or high. -------------------- "To Protect And To Serve The Wealthy" -POLICE
May 12, 2008 - 10:32 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 22, '07 From Houston, TX Currently Offline Reputation: 4 (100%) |
yeah, you ever take off your oil pan? if so you'll see that the baffle is right about at the full line on your dip stick, and when you remove the baffle you'll see the crank sits pretty much half an inch over that. and if i recall correctly the whole length between your full to empty marks it one qt. so that'll give you an idea of how much it is over and how deep your crank is sitting in oil, foaming it up causing all kinda of issues
May 12, 2008 - 10:53 PM
1/2 quart over is not desirable, but it wont be the death of your engine either.
May 13, 2008 - 11:06 AM
I drained it a little, drether be safe than sorry my car dont seem to burn oil (my old celica burned some) so i figured it would be best to be on the safe side.
May 13, 2008 - 11:24 AM
Enthusiast Joined Mar 9, '08 From Cottage Grove, MN Currently Offline Reputation: 0 (0%) |
while the engine was warmed up i checked my oil and was shocked at how overfilled it was, i was wondering will this hurt anything? Thanks for the help you dont want to check your engine oil while the engine is running. if you do it will always read high on your dip stick because the oil is being pumped around in the engine and that can cause a miss read if you check it. you have to let it sit for at least a few min (not 1 min but 5-10 mins) untill you can properly check it. if you drained it while using that reading you took with the engine running, you might be to low now. just wanna like you know |
May 13, 2008 - 2:37 PM
lol it had been settin for a hour or 2 but was still pretty warm to the touch when i checked it
a few minutes ago i let her run for a minute or 2 then let it set and checked it again and its right on |
| Lo-Fi Version | Time is now: August 27th, 2026 - 1:09 AM |
