May 12, 2008 - 5:29 PM
Enthusiast ![]() ![]() ![]() Joined Apr 6, '08 From Overland Park Currently Offline Reputation: 9 (100%) |
I'm looking at getting some KYB strut/shocks and eibach lowering springs, I'm wondering if I also need to get shock and struts mounts as well?? As well as a camber kit?? I'm a newb so cut me slack..
And if there is more than that would you let me know that too?? -------------------- ![]() |
May 12, 2008 - 6:03 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jan 25, '06 From MN Currently Offline Reputation: 19 (100%) |
You don't need a camber kit, but I would recommend getting new strut mounts as your taking the whole thing apart so its good to do it anyways also some new boots would be good too and make sure you get some grease too and an alignment when you settle in your springs.
This post has been edited by Remy: May 12, 2008 - 6:04 PM -------------------- "To Protect And To Serve The Wealthy" -POLICE
May 12, 2008 - 6:05 PM
I'll have it installed professionally since I wouldn't have a clue on wha to do myself
May 12, 2008 - 6:06 PM
I'll have it installed professionally since I wouldn't have a clue on wha to do myself Oh ok I was gonna say I forgot about the spring compresser lol make sure they grease your suspension or you'll be hearing some noises and what not. ![]() Sorry I forgot who made this. This post has been edited by Remy: May 12, 2008 - 6:09 PM -------------------- "To Protect And To Serve The Wealthy" -POLICE
May 12, 2008 - 7:09 PM
Enthusiast ![]() ![]() ![]() Joined Nov 14, '06 From Northampton, UK Currently Offline Reputation: 5 (100%) |
make sure they grease your suspension or you'll be hearing some noises and what not. Other possible causes of popping is the rubber rubber bump stops being too long (Lesjofors 40mm springs require the front stops being shortened by 25mm) or incorrect allignment of the upper spring seat: ![]() I had my car dropped by 40mm today with Lesjofors by a reputable shop and get popping noises from the front now when turning at slow speeds so need to investigate the cause -------------------- Davey
Items for sale |
May 12, 2008 - 9:04 PM
^^^ I'm pretty sure your springs are just settling in its normal if they are installed new.
May 12, 2008 - 11:39 PM
If you have After-market Rims you will need Camber kits for the front. Our cars don't have a Double wishbone supension which can be tuned like civics. So if you have a good mechanic they should be able to tell you tat they can't get your aline-ment to perfect.
May 13, 2008 - 3:17 AM
get new shocks, your drop springs, top mounts, and camber kit while your at it. might as well do it once not like me. installed springs..no new shocks no new mounts.........nada.........waitin on money is all
May 13, 2008 - 4:54 PM
Enthusiast ![]() ![]() ![]() Joined Sep 28, '07 From Toronto, ON Currently Offline Reputation: 5 (100%) |
Its really not hard to remove and install, you just need a spring compressor and an impact gun unless you're the Hulk and think that your muscles can overcome seized bolts and car cancer called rust. There's a how-to on this, I just finished my suspension setup. I'll be taking pics for you soon 808celica!
May 13, 2008 - 9:43 PM
Its really not hard to remove and install, you just need a spring compressor and an impact gun unless you're the Hulk and think that your muscles can overcome seized bolts and car cancer called rust. There's a how-to on this, I just finished my suspension setup. I'll be taking pics for you soon 808celica! -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
| Lo-Fi Version | Time is now: August 11th, 2026 - 11:28 AM |
