> Some questions on lowering.., Tien lowering springs.
post May 15, 2008 - 2:48 PM
Athorn
Joined Jan 4, '08
From Clearwater, Fl
I got a quote from a local shop that it would cost $450 to install tien lowering springs for my car. For those of you who did it yourselfs how long did it take you, what if any problems you ran into, and any advise you have. From just looking at the article in the how to secton it does not look like it would be that hard. I would love for me and my dad to do it insted of wastng $450.Thanks for the help.
Replies (1 - 20)
post May 15, 2008 - 2:53 PM
D-Man
Joined Jan 18, '08
From Houston
Shouldn't be too hard if you do your research first. Know what your getting into, and read up so that you know the answers to questions you never asked. wink.gif
Damn D-Man - most impressive.
post May 15, 2008 - 2:57 PM
DEATH
Joined Dec 19, '07
From tx
It's a 2 hour job at most [4hours for me then tongue.gif ]. Really tho - it's easy. Just rent a spring compressor and be safe - the ghetto way has been known to kill or maim. wink.gif
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post May 15, 2008 - 4:20 PM
hongkongnerdboy
Joined Jul 26, '07
From riverside,CA
labor cost more than springs? o.o
post May 15, 2008 - 4:23 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
haha d-man awesome.
yeah any auto shop like cap or advanced will rent you a compressor, easy job.
post May 15, 2008 - 4:42 PM
96bluevert
Joined Mar 19, '07
From Washington
QUOTE (hongkongnerdboy @ May 15, 2008 - 2:20 PM) *
Yeah, that cost of labor is a b**** when it comes to having work done at an auto shop. kindasad.gif
post May 15, 2008 - 4:49 PM
manphibian
Joined Oct 13, '06
From UK
Yep, it's about $100-$120 per hour here, is it similar in the US?
post May 15, 2008 - 4:52 PM
DEATH
Joined Dec 19, '07
From tx
$75-100 here. Dealership can be more [unless you got the back bay door hookup like me biggrin.gif ]
EXT: WRC/TRD/404
post May 15, 2008 - 8:31 PM
Athorn
Joined Jan 4, '08
From Clearwater, Fl
The bad thing is that is a "friend" ,thanks for the help and yes D-man your right about search . Now i just have to find a way to fix my left back seat because it does not go down..the last person who owned it snapped the little pullly thing off.
post May 15, 2008 - 9:18 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Just take the pully thing from the other side of the seat and screw it into the broken seat. I have done lowering springs on soo many cars I can do that in like 1.5 hours. Plus I didn't charge anyone anything. Well I did charge them for lunch. lol...
94 Celica gt white (sold)
post May 15, 2008 - 10:33 PM
Athorn
Joined Jan 4, '08
From Clearwater, Fl
I iwsh it was that easy... The Pully thing on the broekn seat is snapped off so i dont know how im going to pull the broken piece out.
post May 15, 2008 - 11:14 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
So the pully knob part has snapped off? Or the rod that pulls up that has the knob screwed on snapped off? If its just the knob that snapped off and the plastic some of the plastic part is still screwed onto the threading on the rod you can use a needle nose pliar and screw it off. Now if the rod itself has snapped off, I don't even know.
post May 16, 2008 - 5:10 AM
Athorn
Joined Jan 4, '08
From Clearwater, Fl
No its just the knob part that is snapped off.
post May 16, 2008 - 8:57 AM
DEATH
Joined Dec 19, '07
From tx
Just do what he said - get some needle nose pliers and rotate it off. Then use the other side knob to work both of them until you can get a new one. You could probably get the needle nose to release the seat - it doesn't take much effort to release it.
I had that problem on my last car. I have you beat on this one tho - it had NO hardware for the seats at all. No attachements at the bottom, no seatbelts at the bottom etc. rolleyes.gif
EXT: WRC/TRD/404
post May 16, 2008 - 11:13 AM
Athorn
Joined Jan 4, '08
From Clearwater, Fl
I dont know if i can get needle nose plyers around it because it is flush to the base of it.
post May 16, 2008 - 11:34 AM
Athorn
Joined Jan 4, '08
From Clearwater, Fl
One more question. I am not putting new shocks in. Will i be okay with just the lowering springs? i know the ride quality might not be as good but im okay with that.
post May 16, 2008 - 1:01 PM
96bluevert
Joined Mar 19, '07
From Washington
As long as you're shocks aren't shot, you should be ok.
post May 17, 2008 - 12:13 PM
Athorn
Joined Jan 4, '08
From Clearwater, Fl
maybe this is a dumb question buti know i neeed to cut parrt of the spring. On the sheet it came with it says i need to cut it .5. .5 what?
post May 17, 2008 - 3:01 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
the bump stop
its this foam thing that's on the top of the shock. you'll need to cut i think 1/2 in. off the bottom end of the bump stop. you can run your old shocks like what im doing biggrin.gif only mines are goin goin GONE!!!!!
post May 17, 2008 - 4:17 PM
Athorn
Joined Jan 4, '08
From Clearwater, Fl
What happens if you dont cut that piece off?
post May 17, 2008 - 8:35 PM
Terracar
Joined Mar 28, '08
From Washignton
less suspension travel before it goes thud and you feel it in the chasis - not too big a diff
'92 ST185, '88 ST165, '05 Galant LS, '08 Legacy
Lo-Fi Version Time is now: September 20th, 2026 - 6:22 AM
