May 20, 2008 - 12:13 AM
Enthusiast ![]() ![]() ![]() Joined Aug 31, '05 From Houston TX Currently Offline Reputation: 7 (100%) |
ok so i just got my wiring back from tweak. i started to plug evrything together and i notice that am left with a few grounds that forgot where they go and a few connectors that i cant seem to find where to connect to . also i tried to connect my battery together and i cant find where to conect the positve side of the battery! well i took some pics of the wiring any help will be apraciated. oh and i found that i need a new starter where would i be able to buy one autozone? also i have celica gt tranny on a 3sgte do ineed to be using the starter from the gt or from the alltrac?
GROUNDS ![]() ![]() CONNECTIONS ![]() ![]() ![]() NEGATIVE ![]() POSITVE ??? ![]() -------------------- |
May 20, 2008 - 1:11 AM
that must be a negative.
May 20, 2008 - 10:32 AM
anyone plz am trying to get this thing running
May 20, 2008 - 1:43 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
First pic is the EFI noise filter, that plugs into your harness somewhere and you just bolt it down wherever.
Second pic looks like maybe the EGT sensor from the cat? You don't need that. Third pic is your resistor pack for the injectors, you will use the 5-wire plug that goes to the harness, the smaller 2-wire resistor pack you don't use. Fourth pic I have no idea (need wire colors) Fifth pic is for a ground, you may or may not have the matching connector, not a big deal but make sure that you have a least a couple grounds between the engine and chassis. Sixth pic does look like the negative cable. Seventh pic is the positive power into the harness, that needs to go to your positive battery terminal lug along with the main cable down to the starter. (As I recall you didn't send us the positive cable). If you need more help just give me a call at 404-474-4573 or email. -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
May 20, 2008 - 1:59 PM
Enthusiast ![]() ![]() ![]() Joined Apr 4, '05 From ST PAUL, MN Currently Offline Reputation: 3 (100%) |
once again dr.tweak to save the day!!
This post has been edited by RUNNIN-LOW: May 20, 2008 - 1:59 PM -------------------- ![]() |
| Lo-Fi Version | Time is now: September 12th, 2026 - 12:53 AM |
