> technical stuff about the cruise control lever, for all those 3 spoke steering wheel swappers.
post May 26, 2008 - 3:23 PM
Well i just swapped my steering. I have the dilemma of the cruise control. I have read its a possibility of just joining some wires and give it a try, however bad cruise control can mean acceleration or inability to turn it off. so i decided to see about it.
My new matrix steering did not come with one, buying one is not a problem. However the 7th gen is a 2 wire module and the 6th gen has 3 wires.
as far as comands options on 6gc, i took it apart, very simple switch, consists of 3 resistors wired in a way to provide multiple resistance values for each option. Thats how it does it. By resistance, and the computer reads this.
The question is how to effectively use the 7th gen making sure you get all the functions.
I set my multimeter at 2k setting and here are readings...
1. Cruise On / Off (this is actually a zero resistance switch. ) this is the white and white/black together
The following are the red and white/black together
2. Cancel ( the resistance value on this is 0.419 )
3. Set/Coast ( the resistance value on this is 0.198 )
4. Res/Acc ( the resistance value on this is 0.068 )
here is the basic set up
However the 7th gen has 2 wires, and i need to get ahold of one to take it apart and study it and modifiy it..
Yes the Cruise on the wheel is better.
Until i get my hands on a 7th gen, it is unk what functions can be done or replicated safely. As both computer modules can be different. Ill keep posting...
This post has been edited by njccmd2002: Feb 7, 2014 - 4:38 PM
Replies (1 - 9)
post Aug 31, 2008 - 12:41 PM
got my hands on a triple spoke cruise and different values and just two wires.
The following are the red and white together
2. Cancel ( the resistance value on this is 1.542 )
3. Set/Coast ( the resistance value on this is 0.631)
4. Res/Acc ( the resistance value on this is 0.240 )
so this is different information, this was off a rav 4. now i dont think these same resistances will trigger the cruise computer. And if the resistances are the same in a 7th gen celica cruise.
pretty much both have resistors in series,
2. Cancel 3 resistors
3. Set/Coast 2 resistors
4. Res/Acc 1 resistor
my goal will be to swap resistors, tough job due to size, i have to make holes larger.
here are the pics of different layout.
another view
removed resistors, and had my old cruise resistors.
shaved the pockets
and soldered the resistors needed.
no i will make the wire splicing.
This post has been edited by njccmd2002: Feb 7, 2014 - 4:51 PM
post Sep 7, 2008 - 10:06 AM
KAOS
Joined Apr 18, '06
From Calgary, Canada
Ok so if you buy a 3 post wheel that doesn't have a cruise control module built in - you can't just swap out your existing cruise control module????
By this I mean, my GT-S already has cruise - would it work with my new 3 post wheel? Thanks for helping the newb... smile.gif
post Sep 7, 2008 - 11:17 AM
no dude, if you look at the size of the cruise modules, different hole pattern.
I had here a cruise from a rav. but a celica cruise might have same configuration of resistance. Batman simply spliced and used and it worked for him. The rav one i had did not work therefore i changed the resistors. 2 hour job.
The cruise control does not have to be on the steering wheel tough. any button with the right combination of resistors can do the job if you wire it right.... wink.gif
post Sep 7, 2008 - 1:15 PM
KAOS
Joined Apr 18, '06
Ok so the wheel I bought didn't have a cruise control module on it - can I retrofit the module I currently have to the new 3 post wheel so I can keep my cruise?
post Sep 7, 2008 - 1:45 PM
you can always retro fit but it wont look right. like i sad the mounting screws are different.
post Feb 7, 2014 - 4:23 PM
fixed the pics.. and best shot of order of colors in clock spring
This post has been edited by njccmd2002: Feb 7, 2014 - 4:53 PM
post Feb 7, 2014 - 11:02 PM
richee3
Joined Jun 29, '08
From Denver
Looking everything over again, I'll have to do as we discussed today and take the resistors out of my old stalk and solder them into the new one, or else put my old stalk in the new wheel. It'd be ugly but easy.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Feb 8, 2014 - 8:28 PM
gor to ay radio shack and get new resistors.
post Feb 8, 2014 - 10:55 PM
richee3
Joined Jun 29, '08
From Denver
I'm going to take my old cruise stalk to Radioshack later this week and buy two of each resistor. I'll take care of the cruise stalk on this steering wheel next weekend then at some point later I'll take care of my 7gc wheel, but there's no rush on that one.
1998 Celica GT-
BEAMS Swapped.
Lo-Fi Version Time is now: September 15th, 2026 - 6:45 AM
