> 5sfte MR2 Dyno (megasquirt ems)
post Jun 12, 2008 - 10:02 PM
scooterman
Joined Mar 12, '08
From Mass
this print out shows 197 hp 229 tq.
i did a ton of runs and some tuning max run was actually 198.5 hp 235 tq
this was on a mustang dyno which read low. and according to some this places mustang dyno reads extra low.
run was 2000-5500 rpm
12.8 psi
water/meth 50/50
megasquirt ( tuned myself)
ford edis ignition with msd coil/wires
water/meth droped IAT from 116F to 67F during the 1st run.
red = hp
blue = tq
green = boost
black = afr
Max Torque @ 3100 rpm!!!!!!!!!!!!!!
This post has been edited by scooterman: Jun 12, 2008 - 10:13 PM
Replies (1 - 7)
post Jun 13, 2008 - 11:22 AM
Very nice!
Are you also controlling boost via MS? It looks a bit jumpy.
Fuel curve could also use some fine tuning, but thats probably just the way mustang dyno displays it.
I wish mustangs had as easy to understand layout and dynojets do.
post Jun 13, 2008 - 11:30 AM
DEATH
Joined Dec 19, '07
From tx
Should add this to the Dyno sticky [Just should make sure to plainly label as MR2 5S-FTE] IMO. Moderators may not agree tho - IDK.
Very nice man. I'm dynoing on a brand new Mustang Dyno on monday. Not really concerned with it reading low - just want a basis for comparison from stock-ish [now] at low boost to when I start adding the good stuff/tuning. I'll be using the same dyno everytime so that I can get keep as accurate as possible info [plus it helps that it's a couple of blocks from my house and has 3 pulls for $20 biggrin.gif ]
Just for sh*ts and giggles tho - what percentage is it off vs a Dynojet? And which one is more accurate or is it somewhere in between the two?
This post has been edited by DEATH: Jun 13, 2008 - 11:30 AM
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Jun 13, 2008 - 11:47 AM
There are different theories on this. Truth is, no one really knows for sure. Most people tune on a mustang, and then go make a few pulls on a dynojet, since that is the gold standard for bragging rights dyno numbers.
post Jun 13, 2008 - 12:01 PM
DEATH
Joined Dec 19, '07
From tx
Cool - bragging rights are not really my bag. just trying to get her tuned out correctly and add a modest amount of power. Maybe I'll hit the Dyno jet one day for comparison.
EXT: WRC/TRD/404
post Jun 13, 2008 - 4:04 PM
scooterman
Joined Mar 12, '08
From Mass
that afr is about 13:1 at the highest point shown and 10.3 at the lowest so its a pretty big scale. those jumps in boost are only tenths of afr points.
im using a manual boost controller im going to build one for the megasquirt (gm solinoid) as changing weather causes me to hit my fuel cut some days.
post Jun 13, 2008 - 4:27 PM
How are you hitting fuel cut? I mean, cant you raise it or disable it in MS?
post Jun 13, 2008 - 5:17 PM
great results man.
looks like there is a bit more to gain in the mid range with timing.
we gotta get together some weekend, i'd like to get a bit more in-depth with ya about what exactly your MS setup consists of.
add your dyno to the registry at the top of the forum.
it may not be a celica, but its a 5sfte none the less.
Lo-Fi Version Time is now: September 14th, 2026 - 9:02 AM
