Jul 8, 2008 - 2:58 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 22, '06 From Columbia, MD Currently Offline Reputation: 13 (100%) |
lagos and i are competing in this auto-x and think it would be great to see some other 6gens out competing
it is going to be $45 for non-SCCA members. Pre-Registration closes on friday so hurry! Limited Spots are Available! here are all the details and a link to the direct forum where more info can be found SCCA AUTO-X PAGE LOCATION: Warminister, PA Google Map Track Location TIME START: 8:00 We will be running this event in the AB-CD format. Morning Session: Heat 1 - Group A - STX, STU, STU2, All Mod Classes Heat 2 - Group B - STS, STS2, CSP, DSP, ESP, FSP Afternoon Session: Heat 3 - Group C - SS, AS, BS, CS, DS, ES, PRO Heat 4 - Group D - FS, GS, HS, SM, SM2, ASP, BSP, FSAE, All Prepared Classes Karts will run prior to Heat 3, with the option to take half their runs between the 1st and 2nd runs of Heat 3. Ladies classes may run in either the same heat or the opposite heat in the same session as the corresponding open class. Novice classes run with the corresponding open class. Registration will officially open at 8:15. Registration for the AM heats will close by 9:15 sharp. If you Pre-Register, you must still check in at registration and get your work assignment prior to getting your car teched! AM Session Schedule: * 8:00 - Arrive * 8:15 - Novice Drivers' Meeting * 8:15 to 9:15 - Registration * 8:30 to 9:30 - Tech Inspection / Course Walks * 9:00 - Novice Course Walk * 9:40 - Mandatory Drivers' Meeting * 10:00 - First AM car off * 10:00 to 11:30 - 1st AM Heat * 11:30 to 1:00 - 2nd AM Heat * Start of 1st PM Heat - Trophies PM Session Schedule: * 11:00 - Arrive * 11:15 - Novice Drivers' Meeting * 11:15 to 12:15 - Registration * 11:30 to 12:30 - Tech Inspection * 12:40 - Mandatory Drivers' Meeting * End of AM Session, plus 10 minutes - Novice Course Walk * End of AM Session, plus 45 minutes - Course Walks * End of AM Session, plus 50 minutes - First PM car off * First PM car off, plus 90 minutes - 1st PM Heat * End 1st PM Heat, plus 90 minutes - 2nd PM Heat * End 2nd PM Heat - Clean Up * End of Clean Up - Trophies -------------------- ![]() 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Jul 12, 2008 - 5:03 PM
bump
Jul 12, 2008 - 11:33 PM
Mike, are you doing the AM or PM session?
Jul 13, 2008 - 4:59 AM
i'll be here for both.
| Lo-Fi Version | Time is now: August 11th, 2026 - 11:40 PM |
