> Will 7th gen. GT-S alloys fit on a 6th gen GT?
post Sep 13, 2003 - 1:33 PM
saleeka
Joined Sep 4, '03
From Twin Cities MN
Ive seen a few coupes on this site with 7th gen. gt-s alloy wheels on their cars. Does this just bolt on, or does it mess with the spedo accuracy, and does it fit into the wheelwell without rubbing?
Replies (1 - 8)
post Sep 13, 2003 - 1:44 PM
blkGT
Joined Jun 10, '03
From FL
Will fit, wont rub. And i dont BELIEVE that it will mess with your speedo.
post Sep 13, 2003 - 8:33 PM
FallenHero
Joined Dec 26, '02
From Alabama
If somebody will post up the tire size numbers, we can check.
Here, this is a great place to check sizes out
http://www.miata.net/garage/tirecalc.html
Jon
post Sep 13, 2003 - 11:29 PM
7aek
Joined May 15, '03
From NYC, Queens
for wut i know~~~ factory numbers are 205/55/15. i dunno about the 7th gens
post Sep 14, 2003 - 1:24 AM
Kwanza
Joined Apr 8, '03
From NorCal
The stock height on the tires are the same...no speedo changes...
post Sep 14, 2003 - 2:48 PM
Andason
Joined Jun 26, '03
From Wisconsin
if stock is 205/55/15 the 7th gts are 205/50/16 theres 1/2 inch difference on each side. The speedo will change.
This post has been edited by Andason: Sep 14, 2003 - 2:53 PM
i am awesome
post Sep 15, 2003 - 2:14 AM
Kwanza
Joined Apr 8, '03
From NorCal
QUOTE (Andason @ Sep 14, 2003 - 12:48 PM)
The height is the same...the gts rim is 16 inches as opposed to 15...
205 (width) 55 (height) 15 (rim size) 6th gen
205 (width) 50 (height) 16 (rim size) 7th gen GTS
Basically, the tire on the GTS rims will be around an inch lower in profile beucase the the rim is 1 inch taller...
post Sep 15, 2003 - 3:34 AM
deliriouzgtfour
Joined May 15, '03
From So Cal,CA
QUOTE (Kwanza @ Sep 14, 2003 - 11:14 PM)
the 7th gen 16" gts rims will fit..i used to have them on my car...fits perfect
post Sep 16, 2003 - 10:24 AM
97GTinKC
From KC
Overall diameter of the 2 tire sizes listed here is the same, no speedo difference, the GT-S rims are slightly narrower 16x6.5 as opposed to the 6th gen GT 15x7. Not a big deal. You can even use the 6th gen alloy wheel lug nuts if you dont get them with your GT-S wheels, they just stick out slightly more, the hex part is taller.
Lo-Fi Version Time is now: September 1st, 2026 - 12:07 AM
