> Auto to manual swap help, are these parts interchangeable
post Jul 19, 2008 - 6:10 PM
bringindaheat573
Joined May 10, '08
From missouri
so i have a Gt-4 st 185 front clip here i have a st automatic i have also purchased the s54 tranny and shift linkage and the new axles spec racing stage 2 clutch fidanza light weight fly wheel and i resurfaced the pressure plate from the awd tranny here where im not sure about can i use the shifter assembly, clutch master cylinder,slave cylinder,rubbers clutch line, and the clutch metal fluid lines from my or do i need to purchase them for a 6gc GT to match the tranny?
Replies (1 - 1)
post Jul 19, 2008 - 11:33 PM
all the ST/GT lines are the same (except the rubber line - ST is longer, no biggie - and the metal line on the tranny itself that connects to the slave)
If you have the GT line on the tranny itself, then your fine. Everything else is plug and play.
Note: the ST cluch pedal assembly is different than the GTs, but they both work just fine.
Lo-Fi Version Time is now: August 30th, 2026 - 10:07 AM
