> need help ASAP, car starts and dies
post Jul 23, 2008 - 11:25 AM
ferngt4
Joined Aug 2, '07
From las vegas
So i posted something about this a while back and i got some ideas leading to the igniter but thte part is sooo expensive and with rent coming up i dont see me doing anything. I took my car to school and for 2 phases we tried to figure out what the problem was, we hooked the car up to all the scanners and scopes available, when the car was running the spark line and kv was normal and it just stalled out of nowere. We checked for fuel, (going back to the for basics-spark fuel and compression) when we went to go chek for the spark after everything the teacher just pulled the spark plug wire out to see if the spark jumped and shure enough we had spark, so we left it running like that to see if we lost spark before the engine died again and we left it there for about an 1hr and it ran just fine. i ran the car for 2 more phases and here we are with the same problem again. ANy body have any ideas what it might be? thanks..
Replies (1 - 5)
post Jul 23, 2008 - 11:37 AM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
Sounds to me like it'd be a fuel-related problem, like somehow the engine is being starved or something. Have you checked your fuel pump? Also, this may be dopey, but are you on the same tank of gas you were on when the problem began? I'd question if maybe you've got bad gas running in it - I know that's actually been going around down there in Vegas, on/around Valley View. If you're on the same tank of gas, try draining it, flushing the fuel system and refilling with higher octane just to ensure a good cleanup. Check to make sure your fuel pump is working properly, maybe it's dying and just kind of pooping out on you a while into running.
I'm SO not a mechanic, but since you seem to have checked the ignition system and ruled that out, the fuel system would be the next place I'd look.
post Jul 23, 2008 - 11:39 AM
lubu
Joined Apr 2, '07
From Great Western Plateau
You left the car on idle for 1 hr??
I think its either the fuel pump ( no getting enough fuel or a clog somewhere in the fuel line), the distributor (failed bearing)...these are just stabs in the dark.
98% completion
aaRon
post Jul 23, 2008 - 11:43 AM
ferngt4
Joined Aug 2, '07
From las vegas
no i eventually ran out of gas from testing it 6 weeks. I used gas from the clip cars in school to give me some fuel. I checked the fuel pump, checked regulated pressure dead head and the pump was fine. so that was ruled out as well. yea im not quite a mechanic either, they like to refer to us as technitians..lol. when we cant even fix our own cars. But anywasy cant be the fuel because i havent been back in vegas with the celi in quite some time, im currently living in phoenix for school. Have fun in vegas by the way
post Jul 23, 2008 - 12:55 PM
GriffGirl
Joined Feb 7, '07
Had fun, thanks.
I'm still going with fuel on this one. Bad fuel or clogged fuel line, although I wouldn't think it'd idle for an hour with a clog, however if it was JUST idling, maybe it would since you weren't actually gassing it to pass more fuel through. I just absolutely think it's somehow fuel related. Somewhere. kindasad.gif
post Jul 23, 2008 - 1:03 PM
ferngt4
Joined Aug 2, '07
From las vegas
yea thats what i was thinkin since the car would run when its moving and i get on the gas. I did run the car on E for about 2 days so yea it could be but right now im going to replace the cap and rotor since i had a loose wire there.
Lo-Fi Version Time is now: August 9th, 2026 - 9:04 AM
