Jul 23, 2008 - 11:14 PM
Enthusiast ![]() ![]() ![]() Joined Aug 19, '07 From Farmington, MI Currently Offline Reputation: 7 (100%) |
Okay, so my tranny has been leaking out of this spot for a while, its a e153 in my 3sgte swap. Anyways it leaks out of my refill plug, i have no clue y, i bought a brand new one, and put it on, it still leaks for some reason, also i tighten it enough, so what should i do?
Jul 24, 2008 - 3:13 AM
does it have a "crush washer" on it? (kinda like the oil drain bolt should have, but thicker and metal.)
Jul 24, 2008 - 11:05 AM
umm nope, where could i get one?
Jul 24, 2008 - 2:54 PM
umm nope, where could i get one? most auto parts stores should have them. you may need to bring the bolt with you to get the proper size. -------------------- Former Team 5SFTE pro member ;)
Jul 24, 2008 - 3:02 PM
Mine started doing the same thing from the drain bolt, and it does have a washer on it.
You can just back the bolt out half way and put RTV around it. At least thats what I plan to do. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jul 25, 2008 - 12:23 AM
kk, i gonna try that if i leaks tonight, i out some other stuff around it but will see
Jul 25, 2008 - 2:36 AM
Mine started doing the same thing from the drain bolt, and it does have a washer on it. You can just back the bolt out half way and put RTV around it. At least thats what I plan to do. then its time for a new washer. -------------------- Former Team 5SFTE pro member ;)
Jul 25, 2008 - 11:51 AM
Mine started doing the same thing from the drain bolt, and it does have a washer on it. You can just back the bolt out half way and put RTV around it. At least thats what I plan to do. then its time for a new washer. This is with a brand spankin new bolt and washer on both the oil drain and oil fill sides. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jul 25, 2008 - 8:08 PM
same here, um still leaking with the rtv, i gonna go get a crush washer tommorow
Jul 26, 2008 - 9:34 AM
copper crush washers work good, but both sides need to be clean and smooth. fiber washers i think work better, they'll conform to slight irregularities much better than metal ones.
if its a really bad leak, like dripping, then you need to check for some ****ed up threads or crossed threads. -------------------- |
Jul 26, 2008 - 11:34 PM
ya, i just installed the copper one, still leaks slowly, i gonna buy a fiber wash next i guess, but its so werid that it still leaks
Jul 27, 2008 - 9:47 AM
check the threads, make sure theyre in good shape and not crossed or ****ed up. the only other thing to check is that you havent overfilled the trans.
| Lo-Fi Version | Time is now: August 11th, 2026 - 10:56 PM |
