Jul 31, 2008 - 4:53 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) |
This plate is from the bottom of the caliper. Mine has a broken tab! And causes it to creak and squeal. Anybody?
Jul 31, 2008 - 5:47 PM
GT or ST? Your profile says you have an ST. Are you referring to the backing plate?
Jul 31, 2008 - 7:27 PM
I did a rear disc brake swap from a GT. One of the pad support plates (in the shape of a U - I'll take a picture if absolutely needed) is missing a small tab. The missing tab causes the plate to vibrate which then causes an obnoxious noise. I just added some caliper grease to it as a temporary fix, but every time it rains I have to reapply.
Aug 1, 2008 - 1:32 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Richmond, B.C. Currently Offline Reputation: 0 (0%) |
The pad supports can be purchased at any autoparts store; they come with any set of pads, but can often be found in a pack of brake hardware.
| Lo-Fi Version | Time is now: August 21st, 2026 - 1:19 PM |
