Sep 11, 2008 - 3:54 PM
I didn't wanna threadjack or anything since my clunking noise seems to be totally different than the "clunking while braking" thread... I know my rear struts are blown (there's evidence of leaking) and I'm getting ready to fix that very soon finally. But while I'm up in there I want to fix whatever it is that causes the awful clunking in the rear of my car. It happens mostly when I'm driving on the streets as opposed to highway. At higher speeds (over 45 or 50) it doesn't make the noise. I searched around and have found conflicting reasons that point to either the endlinks or the swaybar bushings (or strut mounts).
Anyone have any input on this, and how to I tell which one it is? I don't want to just arbitrarily replace stuff that doesn't need replacing. Yeah, I'm all for upgrading everything, but a girl's gotta pay the rent too. -------------------- ![]() |
Sep 11, 2008 - 3:57 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 19, '07 From tx Currently Offline Reputation: 22 (100%) |
Griffy - there is nothing arbitrary about this. Replace all of that stuff at the same time or like we discussed - close to it. It's gonna be much better that way - trust me.
Do it right or do it twice as some wise soul once told me [Hmmm - wonder who that was? -------------------- ![]() ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Sep 11, 2008 - 4:39 PM
end links sound like rattling or popcorn popping in the rear
strut mounts clunk when turning wheel bearings can clunk if seized and can make your rotors warp and brakes wear if uneven. bushings will help with small clunks while driving over anything -------------------- ![]() |
Sep 11, 2008 - 5:06 PM
Definitely no rattling or popcorn
Clunks all the time, not just when turning Drums weren't warped at all when I did the disc conversion; 5k miles later the rear rotors seem just fine so far Bushings!!! I can get new swaybar bushings, right? This isn't something where I have to replace the whole thing because of the bushings, is it? Death - I'm gonna have a close look at the endlinks. If they're in one piece and not rusted, I'm gonna leave 'em for now. Gotta get those tires. -------------------- ![]() |
Sep 11, 2008 - 6:07 PM
it helps if you sit in the back and have someone else drive to find out where the sound is coming from...
you can easily tell if it's the strut mounts, spare tire or sway bar bushings, etc... -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Sep 11, 2008 - 6:23 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 29, '04 Currently Offline Reputation: 5 (100%) |
Sway bar bushings are:
cheap easy to replace a common cause to the problem you describe. |
Sep 11, 2008 - 6:29 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 30, '04 From So Cal Currently Offline Reputation: 13 (100%) |
Back then my rear is always clunking when I go over speed bumps, over pot holes, down a drive way, up a drive way, etc. My friend told me I just have to screw in the bolts to the end links tighter. So I lifted up the car, screwed in all the bolts I can see in the back as tight as possible. Clinking disappeared.
But that's just me. Hope it's a simple fix for your also. -------------------- |
Sep 11, 2008 - 6:57 PM
Sweet - I'll check those bolts too.
Okay but how badass would it be if it was just the spare tire! I would seriously laugh my butt off. (I'm really sure it's not... okay, pretty sure). Wait - I know where to get endlinks (twosrus of course) but where do I get swaybar bushings? OMG! I just looked at this and it totally makes sense! I bet that's what it is! YAY! This post has been edited by GriffGirl: Sep 11, 2008 - 7:02 PM -------------------- ![]() |
Sep 11, 2008 - 7:31 PM
read the stickies NOOB
http://www.6gc.net/forums/index.php?showtopic=60744 part #s for the sway bar bushings are listed on the pics -------------------- |
Sep 16, 2008 - 12:44 PM
oh yeah, that.
LOL! Thanks... -------------------- ![]() |
Sep 16, 2008 - 5:57 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Richmond, B.C. Currently Offline Reputation: 0 (0%) |
And then there's the expensive possibility -- bad bushing/bearing in the suspension arms. Those are US$90 each, and there's four of them. Typically, it's the No. 2 suspension arms (the rear arms of the set), but can be the No. 1. Unfortunately, you have to replace the entire arm.
If you're replacing the struts, then you'll want to replace your strut mounts (the mounts take as much punishment as the struts). As noted, replacing the end links and sway bar bushings at the same time is a good idea. Replacing the No. 2 suspension arms on the sixth-gen is relatively easy; the No. 1 arms are much more difficult, as you have to lower the gas tank to get the bolts out on that side. Try this test -- get the car up on a lift with the wheels hanging loose. Stick a pry bar in at the point where the suspension arms connect to the suspension member (the brace bolted to the underside of the chassis) and pry at it. If the arm moves and produces a pop/clunk, you've located your problem. |
Sep 16, 2008 - 6:01 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Feb 18, '06 From NB, Canada Currently Offline Reputation: 12 (100%) |
if its the rear control arms, you can easily do this test :
Jack the rear of the car, take each wheel at 9 and 3, and wiggle, if you can move the wheel around, it's the suspension arms(and their bushings)...that is if the wheel bearing isnt failing (which would be another type of noise). The noise you describe really wheel worn suspension arms bushings and when it's really loud, you can easily move the wheels with your bare hands. You have to change the arms as the bushings are non-servicable and made into the arms. This post has been edited by Rayme: Sep 16, 2008 - 6:05 PM -------------------- ![]() -Rémy 02 SiR, 08 250R |
Sep 16, 2008 - 7:17 PM
^ Actually, I had an '87 Pathfinder that did that, with the wheel moving back and forth, it was scary and alarming to say the least. So when I did my rear brake conversion, I did exactly that to all the wheels, I pushed on them to see if they'd move back and forth like that, and they didn't. Ow chika-wow.
I think I found somebody who knows what they're doing to help me. So hopefully I'll have answers (and a fixed up suspension!) real soon! -------------------- ![]() |
Sep 17, 2008 - 3:47 AM
Unfortunately, the wheel wiggle test doesn't necessarily work to determine if suspension arm bearings are gone, as I discovered. Particularly if they've broken down in an asymmetrical fashion, so that in/out movement is still fine but up/down is compromised.
Sep 19, 2008 - 9:54 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 28, '07 From Banland Currently Offline Reputation: 1 (100%) |
i have this exact noise....just turn up the music
Sep 20, 2008 - 8:53 AM
![]() Enthusiast ![]() ![]() Joined Jan 4, '08 From Clearwater, Fl Currently Offline Reputation: 5 (100%) |
Me mechaninc took a look at my car and found out it just wasnt the bushing it was the whole left arm. I thought it was wosrse than just a bushing.
Sep 24, 2008 - 9:26 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 15, '07 From Fort Worth, TX Currently Offline Reputation: 12 (100%) |
Did you ever replace your sway bar bushings, and did it fix the problem?
Oct 21, 2008 - 6:51 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 8, '08 From Orlando, Florida Currently Offline Reputation: 14 (100%) |
Griffgirl- Was it almost rhythmic clunking? I recently started to hear some clunking like "clunk clunk clunkity clunk clunk, etc" LOL when i was doing less that 20mph and i checked and i fixxeedd ittt!
You do have the GT disc rear conversion right? Well anyway, the source of my noise is a bit difficult to describe but ill give it a go. The bolt that holds the caliper, the 12mm (not the pivoting one that the caliper rotates on) but the one you actually unscrew, theres this rubber boot that is on the caliper, and mine was compressed! SO i just uncompressed it and it revealed a rubber cushion for inbetween where the metal surrounding the bolt on the caliper meet and the metal that the bolt screws into on the caliper bracket. Those two metal things were clunkity clunking. I know that sounds confusing, if anyone has a picture of the rear disc brakes i can easily point it out. -------------------- ◊◊◊ My F/S Thread! ◊◊◊
Oct 21, 2008 - 6:58 PM
My thumping issue (no, not the two 10s in the back LOL) is probably the sway bar bushings. No, I haven't replaced them yet (still), my plate is full of transmission right now
That bolt you're talking about is the caliper pin if it's what I think you're talking about. If so, keep an eye on that because you don't want that piston to seize up on you. If I were you I'd get that caliper off my wheel, pull that pin out and clean up around it, getting rid of any rust or corrosion, and oil up the inside some to get things moving again. Oh and yeah I did the rear disc conversion -------------------- ![]() |
Oct 21, 2008 - 7:04 PM
Autozone sells a universal set of sway bar bushings by Energy Suspension that I might take a look at, as I would like to replace mine. Would anyone happen to know the diameter of the rear sway bar?
http://cgi.ebay.com/ebaymotors/Energy-Susp...sspagenameZWDVW Like those above, but for whatever diameter our sway bar is. -Matt This post has been edited by GotToyota: Oct 21, 2008 - 7:06 PM |
Oct 21, 2008 - 7:07 PM
Nothing was really wrong with the pin, there was just that really old rubber cushion[which was rather deteriorated btw] which was smoooshed up on the pin. I recently had all the parts off and cleaned cause my ebrake components were all wack due to prior owners horrible adjustment.
Anyway since it was a clunk in the rear I felt it was somewhat relevant and worth posting, and different from the clunking while braking. Hope all goes well with your tranny and clunkity-thumping. -------------------- ◊◊◊ My F/S Thread! ◊◊◊
Oct 21, 2008 - 7:32 PM
Tranny will be finished tomorrow night, and clunkity-thumping, well, still trying to find someone who can help me install my damn rear struts and my springs! Ugh.
Oct 21, 2008 - 7:36 PM
If someone could measure the rear sway bar next time they're down there I would appreciate it.
Oct 21, 2008 - 8:56 PM
Alright, I measured the rear sway bar with a dial caliper and it's 16mm.
http://www.energysuspensionparts.com/Unive...ar-Bushings.asp I believe we have non-greaseable bushings, so it should be these: http://www.energysuspensionparts.com/prodd...asp?prod=9.5120 If someone could confirm dimensions of the brackets that would be awesome. These would be cheaper than OEM and would be better. |
Oct 22, 2008 - 12:58 AM
Not a sixth-gen owner, but if your bushings are set up like a fifth-gens, the brackets will be asymmetrical unlike the generic ones. However, I'd be greatly surprised if you could not get replacement Toyota bushings for less than those aftermarket ones -- heck, mine were less expensive than that, and I'm paying the Canadian markup.
Oct 22, 2008 - 9:13 AM
Oh ok. After looking at my brackets though, they look exactly like the ones on the website. I didn't realize that the bushings were less than $15, but I might as well spend a few bucks more and have something better. The question is whether or not they'll work.
-Matt |
Oct 23, 2008 - 3:53 PM
Enthusiast Joined Feb 12, '08 From Norway Currently Offline Reputation: 0 (0%) |
I have the same clicking sound in my car, 1996 St205, and after reading this i know what next week will be all about. I hope i can fix that in a not-sp-expensive way. Ill let you know how it works out. Please keep the suggestions for finding the problem coming! Thanks!
| Lo-Fi Version | Time is now: June 9th, 2026 - 5:05 PM |
