> 3s throttle cable
post Sep 27, 2008 - 10:29 AM
6g25th
Joined Nov 28, '05
My 3s motor is finally set in and I'm working on getting the harness plugged in and the ic set up, but just a little problem. I had a 7afe in there before and I have the old throttle cable, but the cable is too short. Just wanted to know if anyone could tell me what cable I need, wether I could use a gt cable or maybe a 90-93 usdm 3s cable or do I need to special order a st205 cable?
Replies (1 - 2)
post Sep 27, 2008 - 3:43 PM
You can use a 5sfe cable, but it will require modification because its actually a bit too long. When I was using it I put spacers in on the gas pedal side.
post Sep 28, 2008 - 2:20 AM
QUOTE (Supersprynt @ Sep 27, 2008 - 4:43 PM) *
I used a 5s cable with no od at all.
Lo-Fi Version Time is now: May 26th, 2026 - 6:48 AM
