> 3sgte swap, need advice!!!
post Nov 13, 2008 - 10:45 PM
silverceli09
Joined Nov 13, '08
From Indiana
ok, i have a 99' gt with a 5sfe. i am currently saving to purchase a 3sgte. i have found many affordable engines online and they all come with a AWD 5 speed tranny. so, my questions start with, when i swap in a 3sgte what do i have to do to change my car from a front wheel drive to an AWD? or should i only purchase the 3sgte alone with no tranny? can the 3sgte run on a front wheel drive? is it hard to mount up a 3sgte? i love 6th gen celica's and i really wanna make mine a bad ass...soo please help..i really appreciate any information on how to go about a 3sgte swap. thanks alot!!
Celica Or Die, check out http://www.redlinemotive.com!
Replies (1 - 5)
post Nov 13, 2008 - 10:54 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
QUOTE (silverceli09 @ Nov 13, 2008 - 9:45 PM) *
you can but its going to be very expensive
You can, but its going to take a while to source the rest of the parts if you plan on just buying the motor.
Yes look at 10% of the forum members we have the 3sgte swap running on our stock s54 tranny because it bolts right on with a hybrid set-up clutch or running with the e153 transmission with the 3sgte clutch set-up.
No because you have a GT it bolts right in. Out with the old in with the new.i love 6th gen celica's and i really wanna make mine a bad ass...soo please help..i really appreciate any information on how to go about a 3sgte swap. thanks alot!!
94 Celica gt white (sold)
post Nov 13, 2008 - 11:26 PM
silverceli09
Joined Nov 13, '08
From Indiana
ok...so if i swap in the 3sgte will my stock tranny work? and what exactly will i have to change in my clutch..basically, when i drop my 3sgte in, what changes will have to be made? different tranny? different clutch kit? and if so, where can i find these parts?
post Nov 13, 2008 - 11:52 PM
yes you use your stock GT tranny and a hybrid clutch set-up. 5S flywheel, 3s pressure plate and 3s disk with 5s splines IIRC. Clutch companies make the hybris set-up, like SPEC and others.
post Nov 14, 2008 - 8:27 AM
99GT
Joined Dec 14, '06
From MN, USA
Or you can also search.
Look in the stickies above. The big 3SGTE Post. Read it x 2000
post Nov 14, 2008 - 8:37 AM
silverceli09
Joined Nov 13, '08
From Indiana
QUOTE (99GT @ Nov 14, 2008 - 8:27 AM) *
can i find this "hybrid" setup as a clutch kit? or do i have to source the parts by themselves?
Lo-Fi Version Time is now: July 30th, 2026 - 2:51 PM
