Nov 28, 2008 - 3:09 PM
Enthusiast ![]() ![]() Joined Feb 6, '08 From charleston, sc Currently Offline Reputation: 0 (0%) |
should they be that hard to take off the actual light thing?....
like i want to take them off and polish them...make them look good, and what should i use to polish them? -------------------- myspace!!
go FULL THROTTLE or go home |
Nov 28, 2008 - 4:28 PM
Are you talking about the turn signals in the front bumper or the sidemarkers on the fenders? I don't know anything about polishing them but talking both off is easy. There's just one screw on the side you take out then the whole thing comes out on an angle and just pulls right out. It's easy. Someone else will have to tell you the rest bout polishing them though.
Nov 28, 2008 - 8:28 PM
is there a way i can take the actual orange part off?...and its the turn signals
Nov 28, 2008 - 11:09 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) |
Use a rubbing compound, then a polishing compound, then wax to make them look brand new!
Nov 29, 2008 - 12:35 AM
how do i take the orange part off, i dont want to break anything...or do i do the outside of it?
Nov 29, 2008 - 4:40 PM
Enthusiast ![]() ![]() Joined Oct 10, '07 From Sunrise Florida Currently Offline Reputation: 0 (0%) |
put it in the oven for a few seconds and let the glue heat up then use a screwdriver to push the little stopper down so u could pull it off... i would just polish it while its still on the housing though
Nov 29, 2008 - 7:55 PM
u talkin bout the outside?
Nov 30, 2008 - 2:08 AM
I agree with bslik. I'd just leave it all in once piece and polish the lens while it is still attached to the housing. Unless the inside of the lens is dirty. In which case, bslik is still right on the money. Just pop it in the oven for a little bit (temperature?) and then there should be a few tabs holding the lens in place. Pop those off with a flathead screwdriver and you're set.
This post has been edited by richee3: Nov 30, 2008 - 2:12 AM -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Nov 30, 2008 - 9:10 AM
ill just polish it on the outside =]
happening today after church...ill take b4 and after pictures =] im exited!!! lol -------------------- myspace!!
| Lo-Fi Version | Time is now: August 27th, 2026 - 6:51 PM |
