> gauges install? what ones?, hmmm?
post Dec 9, 2008 - 2:22 AM
terbear4god4life
Joined Oct 10, '08
From sweet home, OR
i found some gauges but im wondering what to get i found.
a volt gauge
a vacuum gauge
a water temp gauge
a oil temp gauge
and a oil pressure gauge
my question is how hard is it to install?
idk what i can get i have a non turbo 5sfe in my 94 gt i have a short ram tho..
i only need and can afford 3.
any help?
This post has been edited by terbear4god4life: Dec 9, 2008 - 2:36 AM
"she can polish my strut bar anytime As long as her blow-off valve's in good order"
Replies (1 - 6)
post Dec 9, 2008 - 3:32 AM
xredjokerx
Joined Apr 18, '08
From Oakland, bay area, California
i dont think you need gauges for a nonturbo car.
post Dec 9, 2008 - 3:38 AM
Nial
Joined Aug 25, '08
From England
Oil pressure and Oil temp are the most important gauges to have on ANY car....the standard "Oil light" is a waste of time as by the time its come on its too late, the damage will have been done.
Although the more gauges you have, the more you worry about what they are monitoring and there is more to distract you from the road ahead which is far more important than any gauge.
Unfortunately the Oil temp/pressure gauges are the most difficult to install as you`ll need to fir a take off plate or find somehwere in the engine to mount the sensors.
Water temp is also a good one to have....voltage and vacuume forget about..not worth monitoring on a non turbo car.
My Facebook GT4 Build page.
https://www.facebook.com/groups/GT4Rebuild
post Dec 9, 2008 - 9:33 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
oil pressure isnt hard at all. the sensor they give u can be plugged into an existing hole on the right frontside of the block where a oil sensor is plugged in. take that out and screw in the new one. thats what i did, the only thing is that the red oil light on the left hand side of your gauge cluster will be on all the time
エキサイティングカーレーシングチーム!
post Dec 9, 2008 - 9:42 AM
DEATH
Joined Dec 19, '07
From tx
QUOTE (Tigawoods @ Dec 9, 2008 - 8:33 AM) *
You were intended to use a Tee so that both of the senders would be installed at the same place.
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Dec 9, 2008 - 12:23 PM
terbear4god4life
Joined Oct 10, '08
From sweet home, OR
basically i want 2 gauges i was thinking a volt and something else whats the easiest to install?
post Dec 9, 2008 - 4:16 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
QUOTE (DEATH @ Dec 9, 2008 - 9:42 AM) *
this is true. i did not have one at the time. my original plan was to use the oil sandwich plate technique
エキサイティングカーレーシングチーム!
Lo-Fi Version Time is now: August 21st, 2026 - 11:34 PM
