> Help car wont start, Batt problem
post Dec 15, 2008 - 11:20 PM
whatthe
Joined Aug 13, '08
From Australia
Ok help !!
I was trying to install a short shifter took off the negative terminal on the batt. That was the night before. Together put everything back together. Music plays Dash lights come on. As i try start the car it dies. Now nothing turns on.
What do i do? Jump start the car/batt again?
Replies (1 - 19)
post Dec 15, 2008 - 11:22 PM
Remy
Joined Jan 25, '06
From MN
Before you try to jump start it try checking your fuses first.
post Dec 15, 2008 - 11:24 PM
whatthe
Joined Aug 13, '08
From Australia
^this is going to sound noob as hell but how and which one? The ones under the hood or the ones inside the car? And what do you mean by check?
thanks for the quick reply remy
post Dec 15, 2008 - 11:31 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
did you test the battery? if you have a multimeter. 12v= good. less then 12, you need a new battery.
post Dec 15, 2008 - 11:32 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
So all the lights don't even come on now?
This post has been edited by bccentaur3: Dec 15, 2008 - 11:33 PM
94 Celica gt white (sold)
post Dec 15, 2008 - 11:33 PM
Remy
Joined Jan 25, '06
From MN
Make sure they're not broken like that. Just check every fuse you have it'll be easier lol if your all your fuses are still good we'll move onto step 2. smile.gif
This post has been edited by Remy: Dec 15, 2008 - 11:35 PM
post Dec 15, 2008 - 11:41 PM
whatthe
Joined Aug 13, '08
From Australia
I tried to start it again, this time turned off the radio and everything then tried to start it and just made a low click sound like before and after that no lights or anything. Ill check the fuses now and i dont have a voltmeter
This post has been edited by whatthe: Dec 15, 2008 - 11:42 PM
post Dec 15, 2008 - 11:43 PM
NGHTKD
Joined Feb 2, '06
this happened with my mates 6th gen and it turned out to be a blown fuse
This post has been edited by NGHTKD: Dec 15, 2008 - 11:43 PM
post Dec 15, 2008 - 11:49 PM
whatthe
Joined Aug 13, '08
From Australia
Ok, all the fuses under the hood are good smile.gif. . what now guys? jump start?
This post has been edited by whatthe: Dec 15, 2008 - 11:51 PM
post Dec 15, 2008 - 11:56 PM
Remy
Joined Jan 25, '06
From MN
Yes now try to jumpstart it.
post Dec 16, 2008 - 12:06 AM
whatthe
Joined Aug 13, '08
From Australia
First try, struggled and failed. Second try Success !! Guess i learnt something new today
post Dec 16, 2008 - 12:12 AM
trd_420
Joined Nov 8, '06
From sun valley
if your headlights are dimm its the battery!! JUST GIVE IT A JUMP!!
gLAD WE COULD HELP
post Dec 16, 2008 - 12:23 AM
legalkid86
Joined Dec 14, '08
From RGV, Texas
if the car cannot maintain to stay on while on idle its the alternator its draining your battery and if you cont with a faulty generator it will mess up the batter in return the ecu....
wAkE uP, u'Ll sLeEp WhEn U DiE.....
post Dec 16, 2008 - 12:28 AM
whatthe
Joined Aug 13, '08
From Australia
ok im back again. . .car started i went for a drive(5mins or so) to charge the batt back up.i come back home turned it off. Tried turning it back on and same thing happening again. Should i leave the car on longer to charge the back up more? you rekon its just hasnt been on for long enough to charge the car back up?
post Dec 16, 2008 - 12:34 AM
legalkid86
Joined Dec 14, '08
From RGV, Texas
Its either you have a lose cable that comes directly from the starter, or your battery is completely dead as long as it does not die when your driving it than its not your alternator if it does not turn on after been turned off its your battery...
post Dec 16, 2008 - 12:36 AM
PHLCELICA
Joined Dec 9, '07
From PhiLLy
I've had that problem before. Next time try and move the battery cables to a tight position and see if it'll start.
Celica *The Baby Supra*
post Dec 16, 2008 - 12:38 AM
whatthe
Joined Aug 13, '08
From Australia
Yeh when the car is on and im driving it doesnt die. Only when its off and i turn it on. Thing is its got a new battery 5 months ago. . . Well ive jumped it and going to leave the car on for 15mins and turn it off and turn it back on to see if its going to run. If not something is up
Alright the car was on in my driveway. . and now it just turned off itself. =/
This post has been edited by whatthe: Dec 16, 2008 - 12:39 AM
post Dec 16, 2008 - 12:39 AM
legalkid86
Joined Dec 14, '08
From RGV, Texas
very rare the battery would be the problem, more than likely its the cable from the starter. do you hear it crank though??
post Dec 16, 2008 - 12:42 AM
whatthe
Joined Aug 13, '08
From Australia
yeh i do hear a crank, what do you mean cable from the starter? where is it locateed?
This post has been edited by whatthe: Dec 16, 2008 - 12:43 AM
post Dec 16, 2008 - 12:47 AM
legalkid86
Joined Dec 14, '08
From RGV, Texas
its the positive cable that runs from the back of the starter *near the back of the engine and runs to the positive terminal. check the post remove the cables from the post and reassure the cables and reattach the cables, though if the car turned off that does not sound like your cables it would have to be a faulty alternator does you car have an amp gauge? to see how many volts its putting out??
Lo-Fi Version Time is now: September 20th, 2026 - 8:53 AM
