Feb 10, 2009 - 4:17 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
Has anyone changed teh reverse lights in there tails to LEDs? How diffcult is it, what exactly do you have to do to change the reverse lights?
-------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Feb 13, 2009 - 1:58 PM
Moderator ![]() ![]() ![]() ![]() ![]() Joined Jun 29, '08 From Denver Currently Online Reputation: 59 (100%) |
Changing them out wouldn't be hard at all. It's the same as replacing the bulb. You just take the trim in your trunk out, then you'll see a few nuts that hold the tail lights in place. After that, it's pretty self-explanatory. As far as how bright it would be, I don't know. I would say it would be bright, but not as evenly spread as the bulbs you have now. It would be more like a flashlight pointing out in one direction than the even lighting all around like you currently have.
Feb 13, 2009 - 4:22 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 5, '06 From San Luis AZ Currently Offline Reputation: 4 (100%) |
there was someone who was trying to do that....
but he was doing the entire thing not only the reverse light. it did looked excellent though. but for that you need a circuit board and some electronic knowledge. -------------------- ![]() |
Feb 13, 2009 - 4:29 PM
Enthusiast ![]() ![]() Joined Oct 23, '08 Currently Offline Reputation: 24 (100%) |
Culpable did a full led array for the taillights
Feb 14, 2009 - 10:07 PM
Enthusiast ![]() ![]() Joined Jan 22, '09 From Bremen Currently Offline Reputation: 2 (100%) |
It should be plug and play for everything except the turn signals. FOr those you will need a resistor. I know some bulbs come with a resistor already, but they are a little pricey. Check out superbrightled.com
| Lo-Fi Version | Time is now: August 29th, 2026 - 7:23 PM |
