Feb 20, 2009 - 12:39 PM
ok so i blew my 100 amp alt fuse in the engine bay fuse box how do you remove those fuse i tried but it wont move
Feb 20, 2009 - 12:52 PM
ok so i blew my 100 amp alt fuse in the engine bay fuse box how do you remove those fuse i tried but it wont move its bolted into place. you need to take the fusebox apart to take it out. -------------------- Former Team 5SFTE pro member ;)
Feb 20, 2009 - 1:24 PM
Enthusiast ![]() ![]() Joined Jun 25, '08 From CA Currently Offline Reputation: 0 (0%) |
I've done this before its a real pain in the neck. Well first theres a bolt near the front of the fuse box your gonna wanna take that one off, then the whole front portion of the fuse box can slide off. But you have to slide the Black covering off of the actual inner fuse box (The Whitish colored portion). I used a flat head screw driver to take the hinges off without breaking them (otherwise the black covering will rattle alot). Well I dunno if someone did this to my car before but after I got it off there was a 10mm bolt on one side and a smaller bolt on the other. My 5/16 Deep socket worked on this bolt though. Ounce the bolts are out the Fuse can slide out and then its just a reverse process of putting it back together. Easy
Feb 20, 2009 - 1:38 PM
thanks guys
Feb 21, 2009 - 1:23 AM
| Lo-Fi Version | Time is now: August 4th, 2026 - 4:38 PM |
