Apr 21, 2009 - 1:01 PM
Enthusiast ![]() ![]() Joined Feb 7, '08 From Colorado Springs, CO Currently Offline Reputation: 0 (0%) |
I'm selling parts for a 1992-1996 Toyota Camry (to be specific), but these parts also work for the following:
Toyota MR2 1990-1995 2.2L, non-turbo Toyota Camry 1992-2001, 2.2L Toyota Celica 2.2L 1990-1993 Toyota Rav 4 1996-1997 I have just completed an automatic to a V6 Manual swap as I'm building a stroker set up for my car. Along with this transmission swap, I also went ahead and swapped out the rear drums to a caliper and rotor set up also. With all of that said, here are the parts... NEW and unmounted Lexus ES300 1997-2001 Rear Brembo Rotors (test fitted and didn't fit the way I wanted) for a drum to disc swap - $200 for pair. As you can see, there is no wear on it, just some grease CV Axles and Driveshaft, Left Right. CV Joints are good. Replaced about 30K mi. ago. $100 pair www.megavideo.com/?v=ODJZ1VFP www.megavideo.com/?v=XUJ4Q0PB Automatic Shifter and shifter cable (Has some black interior paint on it) $10 Drive Pulley $15 OBO Steering Knuckles and hubs $100 pair Gen 3 s54 Manual Shifter $10 Rear Drum brakes $75 pair ![]() ![]() ![]() ![]() ![]() ![]() ![]() Automatic Transmission, has about 139,800. It is in GREAT condition, doesn't slip and works perfectly. The only problem with it is that it leaks out of where the vehicle speed sensor is plugged in. Very easy and cheap fix. The mechanic that I had pull the transmission out has driven the car and can tell you that it's fully functional without any problems (except that tiny leak) whatsoever. Here are some videos of my driving when it was in my car, days before the swap. http://www.megavideo.com/?v=2E8AXFV2 http://www.megavideo.com/?v=IBE9B87A http://www.megavideo.com/?v=2C12ORS1 Pictures ![]() ![]() ![]() ![]() $350. Pace, FL 32571 This post has been edited by RichieRichJP: Jun 4, 2009 - 1:53 PM -------------------- |
Apr 21, 2009 - 5:14 PM
Enthusiast ![]() ![]() Joined Aug 29, '08 From AZ, US Currently Offline Reputation: 21 (100%) |
will the steering knuckles & hub back fit a gen6 celica??
Apr 23, 2009 - 10:14 AM
I looked up the part numbers and the steering knuckles as well as the rear hubs will swap over to a 5SFE Automatic 6GC.
Let me know if you want them. -------------------- |
| Lo-Fi Version | Time is now: August 27th, 2026 - 11:35 PM |
