> converted ST185 Tranny question
post May 19, 2009 - 9:39 AM
ok so i have an extra ST185 tranny that im converting to FWD. for those that have done this, what differential did you put in? Aftermarket LSD? OEM MR2? and the next question is... is there a diff i can use that will let me still use my stock axles. i really dont want to go searching for MR2 inners and All-Trac outers
Replies (1 - 7)
post May 19, 2009 - 9:50 AM
QUOTE (Smaay @ May 19, 2009 - 9:39 AM) *
no matter what e153 diff you install, you'll need to get axles.
the 5s axles will not work.
post May 19, 2009 - 1:18 PM
ok with that being said, if i get a Kazz LSD for an SW20 can i use 91-92 non LDS axles?
post May 19, 2009 - 1:20 PM
QUOTE (Smaay @ May 19, 2009 - 1:18 PM) *
god,.. i cant remember.
i wanna say yea, but im not 100% sure. a quick search over on mr2oc should have the answer if someone here dont have it right quick.
post May 19, 2009 - 1:39 PM
good idea, ill check out MR2oc
post May 19, 2009 - 4:39 PM
jeffrosie
Joined Sep 11, '08
From Surrey Unitedkingdom
Yes the KAZ will work or any diff for the SW20 E153 box.
You will need ST185 outers with SW20 inner joints driveshafts.
Been bone by many here - do a search. Best look for Batman722 guide as it explains a lot.
This post has been edited by jeffrosie: May 19, 2009 - 4:45 PM
post May 20, 2009 - 8:22 AM
ok that gives me half an answer im looking for. the second one is if i get a Kazz LSD, which MR2 axles? just the stock 91 axles or the beefier 93 axles. im going to assume the Kazz is ment to be a drop in with stock axles.
post May 20, 2009 - 8:26 AM
QUOTE (Smaay @ May 20, 2009 - 8:22 AM) *
yea, IIRC the aftermarket diffs are able to use the non LSD axles.
Lo-Fi Version Time is now: July 31st, 2026 - 10:12 AM
