> Dash Kit, Anyone done this?
post Oct 17, 2003 - 1:33 PM
Guenther13
Joined Feb 28, '03
I just got an vinyl dash kit from rvinyl.com and I was wondering if anyone has put this on their car yet? I wanted to know how hard it was going to be.
Replies (1 - 2)
post Oct 18, 2003 - 5:43 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
Well , if the manufacturer did a good job cutting the vinyl, which was done using either a laser or a blade, it depends, then it should fit with no problems. You have to prepare the surface, so the vinyl's adhesive will bond right. If you've installed window tints before, then that should be a cakewalk for you. smile.gif
post Oct 19, 2003 - 4:55 PM
Guest_Matthew_*
i would suggest painting your interior
its fuggin simple
just clean it all with alcohol and when you spray it make sure that you do it in very light layers...probably 7 or 8
then get some clear coat and do about 4 layers of that
its way better looking than a trim kit and usually costs less
i got the paint for like $2 or $3 and i got about 5 cans of it
thats only 15 bucks not bad if you ask me and it looks 1000 times better than a trim kit.
Lo-Fi Version Time is now: June 11th, 2026 - 9:47 AM
