> I don't see any oil on my dip stick, what's going on here?
post Jun 18, 2009 - 7:08 PM
vi-tuyen
Joined May 12, '09
hi guys. I have a 95 with 7afe, I just bought this car 1 month ago.
now, I just did the oil change, but when I pull my dip stick out to check for oil level, I don't see any oil on the dip stick,
but then I took my Tundra's dip stick and put in the engine to see If I have any oil, it show I have oils.
what's happen here?
Replies (1 - 14)
post Jun 18, 2009 - 7:11 PM
6GenCelicaST
Joined Nov 15, '07
From Attleboro Mass
Someone may have changed dip sticks. How many qts of oil did you put in?
Surprise buttsecks always works fine for me.
1994 Toyota Celica ST
1977 Harley Sportser XLH
1992 Ford F-350 (plow truck)
Facebook
99Celica
Joined Nov 1, '07
From Santa Barbara, CA
you're like 2 quarts low on oil or parked on a hill. Just give it an oil change and be sure to check the oil level every week or two, it's normal for our cars to use up some oil.
post Jun 18, 2009 - 7:16 PM
vi-tuyen
Joined May 12, '09
QUOTE (6GenCelicaST @ Jun 18, 2009 - 7:11 PM) *
I believe it almost 4 Qt. I change the car about 1000 miles ago.
This post has been edited by vi-tuyen: Jun 18, 2009 - 7:19 PM
post Jun 18, 2009 - 8:11 PM
sounds like u have an oil leak. add more oil.
post Jun 18, 2009 - 9:32 PM
vi-tuyen
Joined May 12, '09
the only leaks that I have is the valve cover gasket and the seal from the distributor. Is that the reason why I lose so much oil? or like 6Gencelicast said, some one may have change the dipstick, the previous owner maybe?
post Jun 18, 2009 - 10:22 PM
Mstoochn
Joined Apr 27, '09
From West Coast Canada
QUOTE (vi-tuyen @ Jun 18, 2009 - 10:32 PM) *
Valve cover/oilpan/distributor are very common YES! but over time within 2000 km's or less you can lose almost 4 qt's of oil from my experience, and not to be to dramatic but YOU CAN REPLACE THE DAMN VALVE COVER GASKET AND SILICONE THE DISTRIBUTOR FOR 35$$$$$$ AND DO IT IN YOUR GARAGE, YOU CAN DO IT IN ALASKA!!! thats alot cheaper than buying oil no?
I had my engine rebuilt in Jan 08 and of course they do a terrible job of that sort of thing so i redid the valvecover gasket and made sure i put a fair amount of FIGP (silicone) on the corners and its been almost a year and a half and i have not lost a drop of oil. people say that every engine burns a little bit of oil. Well sir, mine has not burnt 1/8th of a quart in 16,000Kilometers
post Jun 18, 2009 - 10:56 PM
DEATH
Joined Dec 19, '07
From tx
QUOTE (Mstoochn @ Jun 18, 2009 - 10:22 PM) *
Actually it has - just not an a visible amount. It is a fact that every engine that lubes it's own cylinder walls will burn oil - just not very much.
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Jun 18, 2009 - 11:37 PM
Mstoochn
Joined Apr 27, '09
QUOTE (DEATH @ Jun 18, 2009 - 11:56 PM) *
D****** matt, you no what i mean!
post Jun 19, 2009 - 3:52 AM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
unlike the 5s-fe, the 7afe is known to burn oil to alot of oil after 100k.
Breaking Axles...
post Jun 19, 2009 - 5:56 PM
did you turn the engine off and let the oil collect back down at the bottom of the engine before checking it?
post Jun 19, 2009 - 10:26 PM
vi-tuyen
Joined May 12, '09
damn it burn alot of oil, I ad 1qt to the motor, and I can see the oil now.
thanks guys.
post Jun 19, 2009 - 11:04 PM
Ruroniarc
Joined Mar 19, '09
From Malden, MA
Not to jack a topic, but Mstoochn, do you know what parts I need to fix those oils leaks, maybe some numbers, and a little tiny quick how-to? I'd like to fix my oil leak.
EDIT: Funny story actually, my friend had his friend change his oil. Finished putting the oil in, and the oil level was double. Turns out the stuff that was drained was transmission fluid. That was almost a nightmare. Be -very- careful not to drain your transmission fluid.
This post has been edited by Ruroniarc: Jun 20, 2009 - 11:01 PM
post Jun 20, 2009 - 4:43 PM
trdproven
Joined Aug 2, '05
From Guam
1. low on oil
2. on a major hill
3. major oil leak - check under the car for a pool of oil
4. you cannot use another car's dipstick, they are for different lengths and measurements.
5. maybe you changed your tranny fluid
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jun 21, 2009 - 12:47 AM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
QUOTE (Ruroniarc @ Jun 20, 2009 - 12:04 AM) *
parts... valve cover gasket... can't remember if its one or two pieces... they usually are about $16-$20... dizzy o ring... maybe $3??
both are easy... valve cover gasket... 5sfe... pull your spark plug wires, undo the four nuts on the top where the spark plug holes are... pull off the valve cover gasket... clean both mating surfaces, use something like brakleen in the red bottle and razor blade on the half moons.... put in new gasket and FIPG the half moons on the corners... put cover back on, tighten to spec.
dizzy is just an o ring... two bolts on the dizzy... dizzy pulls out, clean shaft and replace oring... make sure to put a little oil on the oring to slide it back in smoothly and not knick the oring... semi tighten the bolts... use timing light to get correct position... tighten the bolts down the rest of the way to spec.
edit: oil pan is just a whole bunch of FIPG and 10 mm nuts/bolts... really easy but all your oil has to be drained first... then just clean it with the same stuff as above and apply the FIPG in the groove...
This post has been edited by pittfirefighter: Jun 21, 2009 - 12:51 AM
Breaking Axles...
Lo-Fi Version Time is now: August 9th, 2026 - 11:52 AM
