> 5SFE Ignition Timing help please
post Jul 1, 2009 - 6:36 PM
Projek_01
Joined Feb 18, '07
From Calgary, Alberta
So 2 weeks after I installed my 98spec 5S, i discovered that my timing is at 5degrees (obd scanner) vs 10degrees in the manual. I tried turning the distributor but it wouldn't budge much. Does this mean I did the timing belt wrong and installed the belt 1 tooth over? Thanks!
This post has been edited by Projek_01: Jul 1, 2009 - 6:37 PM
Replies (1 - 7)
post Jul 1, 2009 - 7:23 PM
thats not how you check timing.
post Jul 2, 2009 - 4:03 PM
Projek_01
Joined Feb 18, '07
i scanned it with a old fashioned light and a OBDII reader. I am sure the OBD way works because they both say 5degrees.
post Jul 2, 2009 - 8:21 PM
thats now how you read base timing, search.
post Jul 3, 2009 - 9:32 PM
k-weaver
Joined Jun 5, '07
From Santa Maria
Not sure on what the cause of the problem is however I believe on the 96 and up 5sfe you can't turn the distributor to change the timing, the ECU controls it. On the 94-95 you can turn it, difference is on the 96 and up the distributor can only go in one way.
post Jul 8, 2009 - 3:09 AM
Projek_01
Joined Feb 18, '07
thanks for your reply! it is confirmed that my timing belt is on right so that means that i need to find a 94-95 distributor then. Would 5degrees vs 10degree base timing effect my fuel economy and or power? I am assuming the ECU would just make up the difference?
post Jul 8, 2009 - 7:32 AM
http://www.toyotacelicaonline.com/timing.htm check your timing CORRECTLY before wasting money. while you can't advance timing at all on your 96, the procedure to check it is the same as the 91.
post Jul 8, 2009 - 7:35 AM
QUOTE (Bitter @ Jul 8, 2009 - 7:32 AM) *
x2
Lo-Fi Version Time is now: September 2nd, 2026 - 3:11 AM
