> Question on st to ST205, Help!
post Aug 10, 2009 - 4:16 AM
Cubita2
Joined Oct 16, '08
From Tampa,Fl
hey guys im thinking about picking up a st185 Canadian all trac dirt cheap...the cars been wrecked beyond repair and I'm wondering how hard it will be to make my 95 st Celica AT200 into an st205 with st185 Drive train(Motor,transmission,drive shaft,rear sub frame,diff.,axles,and rear suspension) what is required? is it possible? or can i only do front wheel drive with the engine?
This post has been edited by Cubita2: Aug 10, 2009 - 4:18 AM
Replies (1 - 10)
post Aug 10, 2009 - 6:28 AM
Hanyo
Joined Aug 16, '03
From Bay area
it would be very difficult to convert a ST to awd considering there is nothing in common between the two celica frames.
the easiest route to take would be to take the engine and mount it to your existing transmission.
This is actually a pretty common swap, you can read more about it by searching the forums.
post Aug 10, 2009 - 2:33 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
QUOTE (Hanyo @ Aug 10, 2009 - 6:28 AM) *
not quite true
the AT200 frame is closest to the ST205 in terms of AWD setup due to the fact it is based off a 4wd car (caldina? idr)
and his ST tranny will not bolt to the 3s. the C52 is an A series tranny
but no, the drivetrain of the st185 is too different to bolt onto the T20 chassis
post Aug 10, 2009 - 3:08 PM
wait, now how different can the 185 be? since its all going to be fab work in the rear end, just follow the thread about the guy that put a 205 rear end in his ST204 and use a custom drive shaft.
post Aug 10, 2009 - 5:23 PM
pipes
Joined Apr 23, '08
From boston MA
QUOTE (Smaay @ Aug 10, 2009 - 4:08 PM) *
you guys have no idea if you use the rear end of a 205 then u dont need a custom driveshaft its already driveshaft ready
post Aug 10, 2009 - 7:52 PM
Cubita2
Joined Oct 16, '08
From Tampa,Fl
So what your saying is with a st205 rear sub-frame and suspension && drive shaft this awd swap is possible ?? And if im mistaken on this what all parts would i need to make it work? Thanks again guys the help is really appreciated !!!!!
post Aug 10, 2009 - 8:00 PM
pipes
Joined Apr 23, '08
From boston MA
QUOTE (Cubita2 @ Aug 10, 2009 - 8:52 PM) *
look at my profile tthen look for my thread
post Aug 11, 2009 - 3:06 AM
azian_advanced
Joined Apr 18, '05
From Calgary
the st185 rear axles and suspension rods are shorter than the st205 ones. in other words, the st185 rear wheelbase are narrower than the st205. you're better off just swapping the engine.
post Aug 11, 2009 - 5:19 AM
pipes
Joined Apr 23, '08
From boston MA
i thought he was asking about the 205?
post Aug 11, 2009 - 5:48 AM
Cubita2
Joined Oct 16, '08
From Tampa,Fl
QUOTE (pipes @ Aug 11, 2009 - 6:19 AM) *
im asking if the st185 3s motor in my celica would be possibe to do AWD and if not what would be needed?
post Aug 11, 2009 - 1:34 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
you need a e153 or s54 tranny and matching shift cables, and ST205 engine mounts to mate up to the 3s and your ST chassis
Lo-Fi Version Time is now: September 16th, 2026 - 2:17 PM
