> Upgrading injectors, What do I need?
post Aug 13, 2009 - 9:29 AM
joeladam02
Joined Jul 30, '08
From NYC
I have a set of 315cc injectors from a 7MGE Supra.
When I tried them in the 5sfe the car dies at about 4500-4700 rpms in every gear, with the pedal to the rug.
My question is, should this be happening going from the stock 220cc injectors?
Will the computer automatically adjust the fuel output over time?
Or do I need something else to tell it how to regulate the air/fuel ratio?
Replies (1 - 5)
post Aug 13, 2009 - 12:07 PM
Mstoochn
Joined Apr 27, '09
From West Coast Canada
QUOTE (joeladam02 @ Aug 13, 2009 - 9:29 AM) *
get an A/F guage, and possibley SAFC, then you can see whats going on, shouldn't die that early. try resetting ecu first
This post has been edited by Mstoochn: Aug 13, 2009 - 12:23 PM
post Aug 13, 2009 - 1:37 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
Why are you changing your injectors?
Mike W
269awhp / 273ft-lbs
post Aug 13, 2009 - 3:14 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
those are too large. your causing your engine to get overly rich, and die. if anything get 440CC injectors and a 2bar MAP sensor. Or just leave your car stock smile.gif
post Aug 13, 2009 - 3:18 PM
DEATH
Joined Dec 19, '07
From tx
Wait why are you doing this?!? If you think you can get performance by just adding fuel I've got a few things you should read.
if it's for a Turbo job then you will ultimately run lean with those injectors but firstly you need a wideband and some way to tune out the new injectors. I can't believe it's idling ATM - you should be putting way too much fuel to it now.
There must be more to this
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Aug 15, 2009 - 12:36 AM
joeladam02
Joined Jul 30, '08
From NYC
Nope, runs up to 4600-4800 RPM's until the ECU starts trying to lean it out.
But the injectors were really just used for test purposes anyways. Had an engine misfire, and was going to use those injectors to rule out a problem with the original injectors, but it just compounded the issue really.
I think they're out of an older Supra. 315cc light green ones. The only reason I even have them is because some guy named StephenAudet on here sold them to me as 5sfe injectors, when they were really like 4AGZE injectors or something...
Lo-Fi Version Time is now: August 27th, 2026 - 11:03 AM
