> installing lowering springs with out new struts??
post Aug 18, 2009 - 12:31 PM
costa
Joined Nov 6, '08
From locust grove, va
i am looking in to lowering my car. i have decided on springs not coilovers and my question is can i install lowering springs without putting in new shocks. if yes do i need aftermarket shocks or will factory shocks suffice?
Replies (1 - 13)
post Aug 18, 2009 - 1:18 PM
Harold_Fastwaker
Joined Aug 8, '07
From United States
you can run lowering springs on your stock struts. Depending on how low you go will increase the wear out speed of them.
post Aug 18, 2009 - 2:47 PM
AMCMoe
Joined Nov 20, '04
From Carlisle, PA
Factory struts will probably be fine for a while unless they're already worn, then you should just replace them all at once to save the hassle of doing it twice. KYB struts are pretty cheap OEM replacements, you can order front and rear for not much more than $200.
post Aug 18, 2009 - 4:09 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
QUOTE (costa @ Aug 18, 2009 - 7:31 AM) *
yes
after a months of having them you'll have a different feeling in the car, thats when you change it out for KYB GR-2, Bilstein, Konig, or Stock shocks again. Or you'll prolly have enough $$$ for coils biggrin.gif
post Aug 18, 2009 - 4:29 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
KYB struts/shocks ARE oem.
Just hold off on installing until you have an extra $225ish for the KYB stuff, that way you're not doing two uninstallations and two reinstallations.
**** Photobucket
post Aug 19, 2009 - 5:55 PM
richee3
Joined Jun 29, '08
From Denver
QUOTE (95CelicaST @ Aug 18, 2009 - 5:29 PM) *
The KYB GR2's area also warrantied to be lowered up to an inch and a half, so there's a little bit of a safety net there. Otherwise, all I can say is what has already been said, that you CAN put lowering springs on factory struts, but they'll wear out a lot sooner.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Aug 19, 2009 - 7:35 PM
samir0189
Joined Mar 8, '08
From Orlando, Florida
Factory shocks don't last much past 60,000mi. (as i have read..)
More than likely your old shocks are due for replacement anyway, and if you put lowering springs on them you are gonna notice that you need new ones pretty soon.
so..
QUOTE (95CelicaST @ Aug 18, 2009 - 4:29 PM) *
x2.
This post has been edited by samir0189: Aug 19, 2009 - 7:35 PM
My F/S Thread!
Ferdi says (11:29)
post Aug 21, 2009 - 4:47 AM
trdproven
Joined Aug 2, '05
From Guam
I dunno if kybs are OEM because I've had both and they are not the same. looks and size. I measured inside out a toyota strut mount and kyb and they are totally different, in fact they are thicker. When I put one KYB mount only in one side it raised one fender significantly higher. I used a tape measure and indeed they are different. Perhaps there is a chance that KYB is making the new ones as OEM because Toyota's new strut mounts look like KYB but for sure the original toyota mounts are indeed totally different from KYB mounts. They are OEM replacements thats for sure but thats the same as saying aftermarket.
This post has been edited by trdproven: Aug 21, 2009 - 4:50 AM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Aug 21, 2009 - 3:26 PM
costa
Joined Nov 6, '08
thanks for all your help guys. i think im gonna replace them just to be safe.
post Oct 18, 2009 - 12:26 AM
sunwukongg
Joined Mar 10, '08
From Socal, OC
so..if i were to get these megan racing lowering springs..
http://www.upscaleautomotive.com/p-18214-m...ota-celica.aspx
how long will they be good for if im using stock shocks? my car currently has about 176,4xx miles on it right now.
post Oct 18, 2009 - 1:57 AM
Harold_Fastwaker
Joined Aug 8, '07
From United States
most likely not very long. if they are original then running a 2 inch drop will probably kill them pretty quickly.
post Oct 18, 2009 - 2:13 AM
Not to hijack...but what's the quality like on those springs? I'm not looking for utmost comfort, so if they hold up nicely it's a good deal for half the price of Teins...
'90 MX-5 Mariner Blue
'15 Optima Grey
'04 206 GTi silve
post Oct 18, 2009 - 9:52 PM
sunwukongg
Joined Mar 10, '08
From Socal, OC
QUOTE (SwissFerdi @ Oct 18, 2009 - 2:13 AM) *
i don't have them, but i remember reading through the forums that they do provide a nice drop and nice ride. and the guy had KYB shocks too. i think it's pretty worth it from what i know. haha, the price is amazing..aint it? tongue.gif
post Oct 18, 2009 - 9:54 PM
Half the price is most definitely amazing.
'15 Optima Grey
'04 206 GTi silve
Lo-Fi Version Time is now: August 11th, 2026 - 2:41 PM
