> Suspension VS Motor Weight
post Oct 25, 2003 - 1:24 AM
Pandeo
Joined Mar 18, '03
From Quebec
Yo!
I plan to do the big swap(3SGTE) in my Celica 94 ST(7AFE).
Everybody talk about How To do the swap, but my question is about supension and braking..
Does my current suspension(OEM) and Brake (OEM Front disk and OEM rear Drum) is enought for the 3SGTE? Does is the same suspension between AT200 and STxxx?
If I Need to change my suspension, What is your suggestion?And about brake?
What is the weight of this engine 3SGTE, 5SFE, 4AGE, 7AFE?(this part of the topic is to help the Search button!)
Thanx for your help!
P.S. I try the search button, but I find nothing...
Replies (1 - 2)
post Oct 25, 2003 - 9:48 AM
Your suspension components will be fine, but I'd try to upgrade to rear disk brakes in the back, so that you'll have better braking performance. Good luck though, I've tried to buy them from three different people, and it never goes through for one reason or another.
post Oct 25, 2003 - 12:19 PM
boosted_K2
Joined Aug 30, '02
From Michigan
The ST and GT suspensions are different. the STs suspension is made for a lighter load, although it will work fine, eventually upgrading is definatly a good idea.
No but I don't buy it
Cause I'm...
Lo-Fi Version Time is now: August 26th, 2026 - 9:28 PM
