> BOV Installation (3SGTE), Best Placement, Recirculation, IC
post Oct 25, 2003 - 10:52 PM
Jabberwock
Joined Sep 22, '03
1. On the 3SGTE swap where is the best place to put the BOV with a FMIC and with a TMIC?
On the TMIC it seems there is only room between the turbo and intercooler piping, but for FMIC's I see it between the intake manifold and intercooler piping.
BUT where is the best place to put it.
2. Also for a FMIC would there still be stalling or hestations when you shift with a BOV that releases into the atmoshphere?
3. I don't really want to go FMIC, so would an IC fan be sufficient enough (I have the GT4 bumper & hood for venting and the front grille seems to be capable of getting air like a scoop(just a speculation.))
Replies (1 - 6)
post Oct 25, 2003 - 11:02 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
if u have the top mount air/air IC then you will need the fan unless you have a hood scoop like on the alltrac, but you have the gt4 hood so you will need the fan to keep the IC from heat soaking
the best place for a BOV would be betweent the turbo and the intercooler but the most common place with a fmic setup is between the throttle body and the intercooler.
if you have a car that runs with a MAF(st185 3sgte) then most likely you will have problems with an open atmosphere BOV.
there are certain BOV's that work with MAF equipped cars, you could look into those.
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Oct 25, 2003 - 11:09 PM
Jabberwock
Joined Sep 22, '03
Yeah the HKS SSQV with the recirculation fitting is a nice BOV, plus even though quieter it sounds good.
For the fan, since the TMIC is closer piping and has constant air, would it be better or as good as a FMIC (or worse)?
post Oct 25, 2003 - 11:46 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (Jabberwock @ Oct 25, 2003 - 8:09 PM)
it depends.
the response will be great because there is a lot less volume to fill with air and the piping would be a straight through setup.
A fmic will not get heat soaked where the top mount, even with a fan, might.
the climate will have an effect on this. if you live in a hot area, the top mount will lose a lot of efficiency. and it tends to heat soak when idling(like at a stop light or in heavy traffic)
post Oct 25, 2003 - 11:51 PM
Jabberwock
Joined Sep 22, '03
During the HoT Times and Traffic Times would a water spray prevent some heat soak?
Also, if you heat shield a lot and heat shield the intercooler(if possible) would that help also?
post Oct 26, 2003 - 2:35 AM
Guest_Matthew_*
a heat shield wouldnt really do much since everything would be covered up.
i would say to get a fmic and do some custom piping. there are a few people who have done it on the 3s-gte, they will be able to hook you up with some instructions.
post Oct 26, 2003 - 10:52 AM
Best place for a BOV is as close to the throttle body as possible.
If you have a BOV recirculate into the intake, it wont make that nice sound you hear.
This post has been edited by Supersprynt: Oct 26, 2003 - 10:54 AM
Lo-Fi Version Time is now: September 2nd, 2026 - 9:13 PM
