Sep 7, 2009 - 5:22 PM
Enthusiast ![]() ![]() ![]() Joined Oct 16, '07 From Seattle Currently Offline Reputation: 15 (100%) |
I want to go with HR Springs but it seems like KYB is the the only strut/shock available for our cars except for Koni $$$. I need a list of whats needed to do it right ....... thanks
Sep 7, 2009 - 5:37 PM
![]() Enthusiast ![]() ![]() ![]() Joined Aug 8, '07 From United States Currently Offline Reputation: 4 (100%) |
You really only have 4 options
1: Lowering springs on stock struts 2: lowering springs on KYB or stock replacement 3: lowering springs on Koni yellows 4: coilovers each number has a price increase. Want it done right, buy lowering springs with KYBs if you want it done right and at the lowest cost. -------------------- |
Sep 7, 2009 - 5:48 PM
Im kinda in the same boat. I got my tein s-tech...had them for a while and just now getting everything together so i slap them on there. Got a good deal on my struts as well (all 4 only 100!!!). Still need to order new front strut mounts, bellows (bump stops come in that kit). If you want to go all out there are some other things you can get. Im trying to get some new end links, I would like new sway bars, but will settle for new bushings, and a strut bar (not srtut related, but suspension related...sorta)
Sep 9, 2009 - 11:08 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 15, '08 From Royal Oak, MI Currently Offline Reputation: 7 (100%) |
Im kinda in the same boat. I got my tein s-tech...had them for a while and just now getting everything together so i slap them on there. Got a good deal on my struts as well (all 4 only 100!!!). Still need to order new front strut mounts, bellows (bump stops come in that kit). If you want to go all out there are some other things you can get. Im trying to get some new end links, I would like new sway bars, but will settle for new bushings, and a strut bar (not srtut related, but suspension related...sorta) where'd u buy it? -------------------- God made man....
Everything else... Made in China ![]() |
Sep 9, 2009 - 11:20 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 18, '09 From Orlando Currently Offline Reputation: 8 (100%) |
If the KYB's are supposedly a stock replacement, and I assume they work exactly the same (unless there's a difference in compression resistance), then why can't stock shocks be used, IF the vehicle is relatively low-mileage and the shocks are assumedly in good condition?
-------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'90 MX-5 Mariner Blue '93 MX-5 LE '07 Kawasaki Eliminator 125 silver '15 Optima Grey '04 206 GTi silve |
Sep 9, 2009 - 11:43 PM
Enthusiast ![]() ![]() ![]() Joined May 6, '08 From Lisarow, NSW, Australia Currently Offline Reputation: 0 (0%) |
they can be but they usually don't last very long, also yes celicas use kyb but they're hydraulic where as the new ones are gas.
Sep 10, 2009 - 12:12 AM
they can be but they usually don't last very long, also yes celicas use kyb but they're hydraulic where as the new ones are gas. I know they won't last long, but I was looking for an answer to why if they're so similar. That's probably it then. -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
Sep 10, 2009 - 3:44 PM
Im kinda in the same boat. I got my tein s-tech...had them for a while and just now getting everything together so i slap them on there. Got a good deal on my struts as well (all 4 only 100!!!). Still need to order new front strut mounts, bellows (bump stops come in that kit). If you want to go all out there are some other things you can get. Im trying to get some new end links, I would like new sway bars, but will settle for new bushings, and a strut bar (not srtut related, but suspension related...sorta) where'd u buy it? Got it from some guy on Ebay...I thought it sounded too good to be true, so I called up the company and talked to them. Apparently those were the last sets, and after they are out, they are not going to order anymore. So im waiting for them to arrive..should be in a few days. |
Sep 10, 2009 - 4:34 PM
are those all struts(f&R)?
Is it this one? http://cgi.ebay.com/ebaymotors/ws/eBayISAP...RK%3AMEWAX%3AIT its not hard to do the front inserts, right? This post has been edited by nics: Sep 10, 2009 - 4:34 PM -------------------- God made man....
Sep 10, 2009 - 6:44 PM
I want to go with HR Springs but it seems like KYB is the the only strut/shock available for our cars except for Koni $$$. I need a list of whats needed to do it right ....... thanks Rachet(s) 1/2in and 3/8in drives Various size sockets in mm also in 1/2in and/or 3/8in drive Breaker bar(s) Allen wrench set for the swaybar links An Impact gun Spring compressors A tub of grease Lots of towels New shocks Your drop springs of choice ......and top mounts depending on the condition of yours, you should be good with the oems though Might as well get camber bolts either Eibach, Ingalls, etc. Having friends around helps 2hrs max for me Could take about 3hrs max taking your time and making sure everything is set and greased and double checked. -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Sep 10, 2009 - 6:54 PM
are those all struts(f&R)? Is it this one? http://cgi.ebay.com/ebaymotors/ws/eBayISAP...RK%3AMEWAX%3AIT its not hard to do the front inserts, right? Yes that one. All 4, the two sets and the two front carts. As far as to how hard it is to do...dont know yet. Cant be that difficult with a vice! I think the hardest thing would be the end links really (from what ive read). |
Sep 10, 2009 - 7:01 PM
the whole job isnt that hard. 3 top mounts nuts, loosen the shock nut before removing the top nuts.
2 strut to hub bolts and nuts, allen wrench and an open ended wrench for the endlinks, brake lines, and maneuver the assembly out. --compress the springs evenly, remove the already loosened shock top nut, remove top mount, evenly release the spring compressor, replace everything and reverse the steps. -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Sep 10, 2009 - 7:04 PM
are those all struts(f&R)? Is it this one? http://cgi.ebay.com/ebaymotors/ws/eBayISAP...RK%3AMEWAX%3AIT its not hard to do the front inserts, right? Yes that one. All 4, the two sets and the two front carts. As far as to how hard it is to do...dont know yet. Cant be that difficult with a vice! I think the hardest thing would be the end links really (from what ive read). but the part numbers for the front are inserts so, how did you managed to get struts for the front with it? i called them sometime ago but the guy who spoke to me sounds retarded -------------------- God made man....
Sep 11, 2009 - 12:11 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 24, '08 From Orange County, CA Currently Offline Reputation: 33 (100%) |
you dont really need camber bolts. I did alignment 3 times after I installed tanabe df210 with gr-2 about a year ago. my spc camber bolts are sitting in my room waiting to be put on, but that wont be until i get coilovers
-------------------- Group buy to replicate Narrow E series transaxle parts
http://www.6gc.net/forums/index.php?showto...p;#entry1107514 Items for Sale: http://www.6gc.net/forums/index.php?showto...p;#entry1107572 |
Sep 11, 2009 - 4:33 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Richmond, B.C. Currently Offline Reputation: 0 (0%) |
If you're doing a strut and spring replacement, you might want to add a few more parts to the list:
1) spring seat insulators (four front, two rear) 2) anti-sway bar end links (getting the stock ones off without destroying them is nigh impossible unless you've a desert-kept car) 3) strut mounts I make these points under the assumption NWCelica has a car from the Pacific Northwest, where rain is a factor -- or more pointedly, rust. If it's a 1999, you might skip the strut mounts, but much older and you'll find there's a value to new items. As a side note, the KYB GR-2 have a warranty. Unlike most struts in their price range, the warranty is good if you drop your car as much as 1.5". |
Sep 11, 2009 - 4:50 AM
are those all struts(f&R)? Is it this one? http://cgi.ebay.com/ebaymotors/ws/eBayISAP...RK%3AMEWAX%3AIT its not hard to do the front inserts, right? Yes that one. All 4, the two sets and the two front carts. As far as to how hard it is to do...dont know yet. Cant be that difficult with a vice! I think the hardest thing would be the end links really (from what ive read). but the part numbers for the front are inserts so, how did you managed to get struts for the front with it? i called them sometime ago but the guy who spoke to me sounds retarded Say what? Correct, what I have ordered are the two front inserts. As well as the rear struts (which are one whole part..housing and cart). There are three P/N listed. # Front: 365092 # Front: 365092 # Rear: 334125 # Rear: 334126. The guy I spoke with sounded fine with me, but we'll see when they arrive...which should be soon. |
Sep 11, 2009 - 11:37 AM
are those all struts(f&R)? Is it this one? http://cgi.ebay.com/ebaymotors/ws/eBayISAP...RK%3AMEWAX%3AIT its not hard to do the front inserts, right? Yes that one. All 4, the two sets and the two front carts. As far as to how hard it is to do...dont know yet. Cant be that difficult with a vice! I think the hardest thing would be the end links really (from what ive read). but the part numbers for the front are inserts so, how did you managed to get struts for the front with it? i called them sometime ago but the guy who spoke to me sounds retarded Say what? Correct, what I have ordered are the two front inserts. As well as the rear struts (which are one whole part..housing and cart). There are three P/N listed. # Front: 365092 # Front: 365092 # Rear: 334125 # Rear: 334126. The guy I spoke with sounded fine with me, but we'll see when they arrive...which should be soon. i see i was planning to order it there but skeptical bec. the price was so cheap. others are priced around 200+ let me know when u receive it. -------------------- God made man....
Sep 11, 2009 - 2:50 PM
i will. Hopefully when i get home they will arrive
Sep 14, 2009 - 11:52 AM
i will. Hopefully when i get home they will arrive any update? -------------------- God made man....
Sep 14, 2009 - 5:23 PM
Not yet...I kind of wonder why people go through UPS at times....limited hours, dont deliver on weekends....So tomorrow is the last day of quoted shipping (and it would figure), I should see it then. Getting anxious though.
| Lo-Fi Version | Time is now: September 12th, 2026 - 1:43 AM |
