> turbo!!!!!, what do you guys think....
post Oct 24, 2009 - 10:58 PM
dans_st
Joined May 24, '03
From Andrews TX
ok, so i am getting back to work on my celica and i already bought new 4afe/7afe manifold with t25 flange.. so now i need an internally waste-gated turbo
my thoughts so far are to go with a Garrett GT2252
so what are your thoughts on it.... i WAS also considering gt2052 but it seemed a bit small and from what i have found a little more expensive...
so any thoughts????? any other info you need???
If anyone is missing NASCAR and it's not on Speed Channel, take a fistful of Skittles, throw them in the toilet and hit the flush handle. Instant NASCAR!!!
Replies (1 - 11)
post Oct 24, 2009 - 11:41 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
U know some pictures would be nice so we can drool over it.
post Oct 25, 2009 - 2:13 AM
Harold_Fastwaker
Joined Aug 8, '07
From United States
This is to turbo a 7afe correct?
Did you look at the compressor map and figure out if the turbo is sized properly for the car?
post Oct 26, 2009 - 12:19 AM
Mstoochn
Joined Apr 27, '09
From West Coast Canada
too small!!!
post Oct 26, 2009 - 9:13 PM
dans_st
Joined May 24, '03
From Andrews TX
too small?
yes this is a 7afe
before i had too big, so that turbo would be too small?
garrett has it listed that it will work from a 1.7l to a 2.5l and hp rated from 150hp-260hp
so wouldnt this work out?
well here are the specs for it:
turbo specs here gt2252
so any suggestions?????
this week i am ordering the oil filter relocation kit and i was planning on ordering the turbo if it sounded like a good idea but i guess i'm waiting, what do you guys suggest
oh and sorry, yes i did look at the compressor map but i am barely learning, i am about to go home and look at some more maps and re-check my math
post Oct 28, 2009 - 7:09 PM
dans_st
Joined May 24, '03
From Andrews TX
so is there anyone out there good with compressor maps that would be able to help me, i am kind of new to them and by my understanding i thought the gt2252 would be a great option and spool very quickly?????
so anyone?
and think this might help...
post Oct 29, 2009 - 5:44 PM
Harold_Fastwaker
Joined Aug 8, '07
From United States
http://www.6gc.net/forums/index.php?showtopic=20291&st=0
go there so you can understand how to read them properly.
post Oct 29, 2009 - 6:44 PM
domyz
Joined Jul 29, '07
From Quebec, Canada
Your choice is okay but I would go for 2259 in your case, for more potential
On 3sgte the turbo is the size of a gt28 and there is NO LAG
LAG isn't an issue on a 2.0liters w/gt28
So I imagine that the 2259 would be good for your application. It should get at full boost in the 2500rpm range, which is very fast.
For about the same lag and more power output, you could buy the more pricey GT2560R, which is ball bearing.
This post has been edited by domyz: Oct 29, 2009 - 6:46 PM
post Nov 5, 2009 - 5:06 PM
dans_st
Joined May 24, '03
From Andrews TX
GREATTTT!!!!!
i get paid wed. and i should have enough to order turbo if nothing else comes up, i will look into it and thanks for the options.
i want something that would spool fast and i read the maps and the 2252 looked close to what i wanted but i knew i was close to the limits of it but i would be extremely happy if i could get 230-250hp and that was where that turbo maxed out at, but bigger and about the same lag sounds good too so i am going to start looking into prices
i know its kinda big but what about this:
http://cgi.ebay.com/ebaymotors/OBX-TURBO-H...=item5ad481f43d
This post has been edited by dans_st: Nov 5, 2009 - 5:17 PM
post Nov 20, 2009 - 10:27 AM
do not get a cheap Ebay turbo. although some have had good luck with them, its not worth the crap shoot IMO. another good turbo for your setup is a Garrett T3 super 60. Its the turbo i use in the 7th gen kits. It spools super fast, has a good MAP and its fairly cheap.
post Nov 22, 2009 - 8:55 PM
speed-CCNP
Joined Mar 11, '09
From Baltimore, Maryland
What was the final decision? I'm in need of a turbo. I think I killed mine.
http://i922.photobucket.com/albums/ad61/do...1-21_214320.jpg
I'm not sure if I should rebuild the one I have or look for a new one.
post Dec 26, 2009 - 5:42 PM
dans_st
Joined May 24, '03
From Andrews TX
I had a local turbo builder build me the gt2252 the turbo is on but car is still in peices so i don't know how it runs yet
Lo-Fi Version Time is now: August 23rd, 2026 - 9:45 PM
