> Engine Coatings, What is everyone using with success
post Oct 26, 2009 - 7:55 PM
qatar11
From Lake Orion, MI
So I'm thinking of getting some engine parts i previously had powder coated in a glossy finish stripped and either going with
- Satin paint
- Satin powder coating
- Black Anodizing
Parts in question
Hardline Tubes
Valve Cover
Oil Sub Plate?
Various Brakets
What is everyone using? And are you having success with regards to durability?
This post has been edited by qatar11: Oct 26, 2009 - 8:03 PM
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
Replies (1 - 7)
post Oct 26, 2009 - 7:58 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
it depends what parts you are talking about... paint works fine, powder coating holds up a little better and doesn't loose its shine quite as easy, anodizing is overkill... if you're going just black, painting will work just fine...
Breaking Axles...
post Oct 27, 2009 - 2:41 AM
razor7
Joined Jul 9, '08
From California
Don't bother with annoing anything,
it's SUPER costly, and frankly not worth it in my opinion. Powder coating will definitely last with heat and vibrations, but again, will be pricey. Unless it's a show car, I wouldn't be investing a ton of money into engine bling...
-TC
Live your life for yourself. Don't hold back for anything or anyone.
post Oct 27, 2009 - 7:08 AM
qatar11
From Lake Orion, MI
QUOTE (razor7 @ Oct 27, 2009 - 3:41 AM) *
-TC
Not so much bling as..... good engine hygene - I want the engine to look clean and kept when I put it in, and I don't want all the coating to flake off after 1000 miles, assuming of course that the car doesn't burn down to the ground.
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post Oct 27, 2009 - 4:24 PM
razor7
Joined Jul 9, '08
From California
QUOTE (qatar11 @ Oct 27, 2009 - 5:08 AM) *
-TC
I'd just get engine enamel, or high-temp paint and do multiple coats (probably 4-5). It'll last, that stuff is resilient as hell, I got some on my finger nail, and it stayed on there until I cut it off months later... and I wash my hands a lot...
-TC
post Oct 27, 2009 - 7:24 PM
to powder coat the block you'd need to totally tear the engine down to a bare block, get it hot tanked and the outside bead blasted, then masked, powdered/baked. you have to take the engine out of the car and totally apart.
post Oct 27, 2009 - 8:58 PM
razor7
Joined Jul 9, '08
From California
QUOTE (Bitter @ Oct 27, 2009 - 5:24 PM) *
I believe that he is doing this to a spare engine that will then be re-installed into the bay. However, I agree, it's a LOT of work...
-TC
post Oct 27, 2009 - 9:33 PM
well if thats the case...
Lo-Fi Version Time is now: July 9th, 2026 - 5:49 AM
