Nov 14, 2009 - 6:42 PM
Enthusiast ![]() ![]() ![]() Joined Aug 14, '05 From St. Paul, MN(USA) Currently Offline Reputation: 8 (100%) |
like title says....i need the sub harness for 3sgte..if any one has eone lying around let me know
Nov 15, 2009 - 4:02 PM
like title says....i need the sub harness for 3sgte..if any one has eone lying around let me know engine harness?? 2nd gen? 3rd gen? -------------------- Breaking Axles...
Nov 17, 2009 - 10:47 AM
like title says....i need the sub harness for 3sgte..if any one has eone lying around let me know engine harness?? 2nd gen? 3rd gen? not the actual engine harness but the sub-harness that connect to the coolant pipe right under the distributor. That sub harness connects there and onto the main engine harness. 2nd gen |
Nov 17, 2009 - 1:09 PM
where does it connect to the main harness?? i have two 3sgte 2nd gen harnesses in my garage from DG
Nov 17, 2009 - 6:54 PM
it should be the harness that connects to the coolant pipe under (but in front) of the distributor....that sub-harness then connects/clips to the engine harness. Its the harness that is clipped onto the top mount ic. I will take pictures later to show you which part im talking about
This post has been edited by team_omega: Nov 17, 2009 - 6:55 PM |
| Lo-Fi Version | Time is now: September 14th, 2026 - 4:56 PM |
