> 5th gen suspension on a 6th gen
post Nov 14, 2009 - 8:46 PM
Joe_1985
Joined May 3, '09
From jacksonville/flemming island florida
ok so i aquired a complete set of kyb shocks, h&r springs with boots bumpstops and mounts assembled
the rear set up ever thing bolts into place no problem
the front,99% seems to bolt up fine cept the brake hosess.
6th gens are held in with a 12mm skrew and bracket
5th gens are held inplace with a slider type clip, and the hose goes though the opening where the clip sits
ill try to take pics tomarrow
what i will try to do is take a washer that fits the 12mm skrew, put it behind where the hole is and get a correct fitting nut for the skrew as well.
ill post pics up tomarrow
also i noticed the front strut mounts are different, everything lines up fine but the mounts look alot different , but yet everything bolts on fine.
i wont be able to test it out till monday morning because i poped out the cv axles to replace em but im waiting for em to come in still, which will be monday
This post has been edited by Joe_1985: Nov 14, 2009 - 8:47 PM
94 stx coupe, super mario kart beater
87 toyota 2wd truck, rebuilding engine
85 celica gt-s project
Replies (1 - 2)
post Nov 14, 2009 - 11:42 PM
bdub215
Joined Jul 7, '09
QUOTE (Joe_1985 @ Nov 14, 2009 - 8:46 PM) *
about the strut mounts: fits because its the same chassis. looks different because one probably supports more weight. that'd be my guess.
90 Toyota Celica (S53) totaled R.I.P
98 Toyota Corolla (C59) 183k 117whp needs a tune
93 Lexus ES300 (E53) 120k Its a stick
95 Lexus Sc300 AutoTragic FTL
post Nov 27, 2009 - 4:54 AM
Joe_1985
Joined May 3, '09
some notes after driving on my setup for a bit
if you dont get it alighned you will chew though tires
also, my camber and toe seem to be way off the outsides of my tire wore quickly and i ruined 2 225/45/16s in a month in a half, as of now im on the stock bbs but im going to get a alighnment check today to see if i can getaway with getting some camber bolts
ill post back later on, also sorry i havent gotten pics up yet, cant find my sd card, guess ill get a new one soon
Lo-Fi Version Time is now: August 23rd, 2026 - 4:16 PM
