> No heat!!
post Dec 9, 2009 - 2:43 AM
Dangercart1
Joined Dec 8, '09
I just bought 94 Celica gt hatchback and it has no heat being that its December this is a bit of a concern! I bought it from a friend and so far we have burped the coolant and tomorrow we will be changing the thermostat but if that doesnt work are there any suggestions?
Replies (1 - 19)
post Dec 9, 2009 - 4:10 AM
Mstoochn
Joined Apr 27, '09
From West Coast Canada
QUOTE (Dangercart1 @ Dec 9, 2009 - 2:43 AM) *
heater core is leaking, does the air smell like antifreeze?
post Dec 9, 2009 - 3:27 PM
Dangercart1
Joined Dec 8, '09
I'm not smelling any antifreeze, how would i check for this? are there any other possibilities?
post Dec 9, 2009 - 3:41 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
have the car up to operating temp and touch the hoses going to the heater core on the fire wall. You could also pull up on the carpet on the passenger side to see if there is coolant puddling up on the floor pan.
Look at the heater valve on the fire wall to see if the valve is actually open. The little thing that has a metal cable attached to it. should be towards the firewall. If its not towards the firewall its stuck closed not allowing heat to flow into the heater core. The valve should have a heater hose coming from the coolant pipes and then going into the firewall.
94 Celica gt white (sold)
post Dec 9, 2009 - 3:51 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
Replacing your thermostat will probably do the trick. If your heater core were leaking, you'd know it, there'd be no mistaking the smell of antifreeze in your car.
post Dec 9, 2009 - 4:06 PM
Dangercart1
Joined Dec 8, '09
i replace the thermostat today and nothing, i haven't noticed any leaking antifreeze but i will check the valve i also no for a fact that both hoses are heating up
post Dec 9, 2009 - 4:09 PM
Fate
Joined Nov 30, '04
From Atlantic City
your friend is a jerk that sold you a car with no heat! haha
post Dec 9, 2009 - 4:12 PM
Dangercart1
Joined Dec 8, '09
QUOTE (Fate @ Dec 9, 2009 - 4:09 PM) *
Lol at least it runs better than my old car
post Dec 9, 2009 - 4:27 PM
6G96GT
Joined Jan 20, '08
From East Coast
Good luck with it.
This post has been edited by 6G96GT: Dec 9, 2009 - 4:28 PM
post Dec 9, 2009 - 4:28 PM
GriffGirl
Joined Feb 7, '07
QUOTE (Dangercart1 @ Dec 9, 2009 - 1:06 PM) *
flush your radiator, maybe you've got a clog to the heater core
And for the 7th gen guy (actually for both of you) are you sure you're letting the car run long enough? The whole country is in a huge cold snap right now, they take a while to get going and warm up before some heat comes out of it. Drive it around for 15 or 20 minutes and if the heat still doesn't come on, then continue investigating. Make sure your A/C isn't on too lol
This post has been edited by GriffGirl: Dec 9, 2009 - 4:31 PM
post Dec 9, 2009 - 6:18 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
you might have a clogged heater core like griff said. But why would both the inlet hose and return hose be hot? If its clogged coolant will go to the heater core, but can't return. Check to see if the valve is open, and that when you turn the heat on inside the car, its actually set on heat. The 4th gen celicas run into this issue.
post Dec 9, 2009 - 6:25 PM
Dangercart1
Joined Dec 8, '09
QUOTE (GriffGirl @ Dec 9, 2009 - 5:28 PM) *
Yeah i drove it for an hour on a highway last week through multible snowstorms with no heat the whole way I will check the valve (whenever I find it!) and i will get the oil and coolant flushed next week (after pay day!)
Thanks a lot for the help everybody i will keep you posted!
post Dec 9, 2009 - 6:43 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Is the heater core being bypassed alltogether? That would definitely give you no heat.
**** Photobucket
post Dec 9, 2009 - 8:12 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
No he said that the hoses are going to the firewall. Unless someone took the time to pull the dash and take the heater core out and just put a loop behind the dash. But I highly doubt someone would go through the trouble of removing the dash and no replace a $50 piece.
post Dec 9, 2009 - 11:10 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
there are two valves that have to be turned to get heat to the heater core... one is at the firewall like mentioned... the other is at the drivers right foot... it has a blue cable going to it... make sure its open as well...
MOST LIKELY the problem is an air bubble caught in the heater core
Breaking Axles...
post Dec 9, 2009 - 11:20 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Yeah.. The valve inside the car basically opens up the heat. You will definitely here it open and close if you unlatch the cable. Just jack the car up, have the heat on full blast and try to get that air trapped inside out.
post Dec 9, 2009 - 11:35 PM
Dangercart1
Joined Dec 8, '09
So i checked the first valve and its fine just read about the second valve I will look for that next, how would I get the bubble out just jack the car up, blow the heat and wait or is there more to it, also where should i jack it up front, back, left, right side?
post Dec 10, 2009 - 12:01 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Jack up the front or park on a incline or on ramps. Open the rad cap turn the car on and have the heat on full blast. If you did have air in the system when the thermostat opens up the air should come out. But the burping process might take a while.
post Dec 24, 2009 - 12:39 PM
Dangercart1
Joined Dec 8, '09
Finally figured it out! Turns out the heater core was clogged! Thanks for all the help
This post has been edited by Dangercart1: Dec 24, 2009 - 12:39 PM
post Jan 30, 2018 - 5:23 PM
97Celica
Joined Nov 27, '02
From Derry,NH USA
QUOTE (Dangercart1 @ Dec 24, 2009 - 12:39 PM) *
and you cleaned it out with a hose?
Were both your hoses warm?
Lo-Fi Version Time is now: August 29th, 2026 - 3:33 PM
