> Help needed with wheel bearing!, in need of quick info
post Jan 5, 2010 - 2:37 AM
Penkka
Joined Dec 20, '07
From Valkeakoski, Finland
Okay, so my front rightside wheel bearing has started to make noise, and is in need of change.
I hope the noise is from the braring, not the driveshaft..
but the thing is this, at local dealership the price was 206€, so its 300$ for a bearing.
un-original part, is only 60€ = 86$..
but they couldn´t tell for sure is it a perfect fit, so does anyone have a clue of the bearing size?
Could it be 74 mm outer diameter, 38mm inner diameter and 36mm wide?
thanks, Penkka.
320hp @ 6300rpm and 420Nm @ 3250rpm. yay!
My ST205 WRC buildthread
Replies (1 - 11)
post Jan 5, 2010 - 2:53 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
are gt4 and usdm gt's alike?? you might wanna go get price checks with shops for a wheel bearing change.
post Jan 5, 2010 - 8:00 AM
azian_advanced
Joined Apr 18, '05
From Calgary
wheel bearings for all celicas are the same... whether it's a gt4 or not. so i don't think there will be any variations in sizes when you go out and buy it.
This post has been edited by azian_advanced: Jan 5, 2010 - 8:01 AM
post Jan 5, 2010 - 10:53 AM
Penkka
Joined Dec 20, '07
QUOTE (azian_advanced @ Jan 5, 2010 - 8:00 AM) *
is that 100% sure? im pretty sure the price isnt the same..
post Jan 5, 2010 - 2:12 PM
zoik
Joined Aug 28, '07
From france
theres a difference beetween wheelbearings, depending if you have or not abs. Have to check this, but i'm almost sure its right
post Jan 5, 2010 - 5:48 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
QUOTE (Penkka @ Jan 5, 2010 - 2:37 AM) *
thanks, Penkka.
make sure its the bearing. jack the car in the air and place your hands at 12 and 6 on the wheel of question. rock it back and forth. if there is play the bearing is the culprit!
i just did a bearing word of advice if you are doing it yourself. follow the procedures carefully. my friend and i pressed the bearing in and forgot to put the outer seal in. all is fixed now, but the could have been a pricey mistake.
post Jan 5, 2010 - 10:33 PM
Penkka
Joined Dec 20, '07
Zoik: yeah there are different bearings on abs/non-abs models.
Garin: I´ll check it tomorrow.
And Garin, you dont happen to have the old bearing? If you could measure it?
post Jan 5, 2010 - 10:39 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
QUOTE (Penkka @ Jan 5, 2010 - 10:33 PM) *
sorry its in the trash. are you going to do this project yourself?
post Jan 5, 2010 - 10:43 PM
Penkka
Joined Dec 20, '07
yeah, its not that big of a deal?
post Jan 5, 2010 - 11:12 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
well just make sure you do it right... have you ever done one before? using a press i hope...
post Jan 6, 2010 - 8:20 AM
Penkka
Joined Dec 20, '07
done much bigger things, the only problem about this is finding the rightsized bearing!
post Jan 6, 2010 - 9:41 AM
garin
Joined Aug 12, '07
From Lancaster, Pa
yea, i'm just saying make sure you do it right the first time... not a hard project, by any means.
the bearings in celicas are unsealed. make sure you get both seals. if you trying to find another bearing to work make sure you compensate for the inner and outer seal...
This post has been edited by garin: Jan 6, 2010 - 9:43 AM
Lo-Fi Version Time is now: May 24th, 2026 - 9:50 AM
