Jan 17, 2010 - 5:21 PM
Enthusiast ![]() ![]() Joined Sep 11, '08 From Surrey Unitedkingdom Currently Offline Reputation: 1 (100%) |
The 99 3SFE in UK has 2 coil packs each feeding 2 cylinders, so 1 gets a spark on compression and 3 gets it on exhaust. Same with 2 and 4.
Is the 5SFE the same as this or does it come with a distributor? Reason I'm asking is because I want to drop a 3SGE in my car in place of the 3SFE, but use all the FE electrics and have it all sdjusted usinga fuel & ignition controller as these are the 2 values that will have to be changed. Apexi SAFC II will be used. Will it work? |
Jan 17, 2010 - 5:38 PM
Enthusiast ![]() ![]() ![]() Joined Apr 27, '09 From West Coast Canada Currently Offline Reputation: 0 (0%) |
the 5s-fe uses a dist, just like the 3sfe This post has been edited by Mstoochn: Jan 17, 2010 - 5:57 PM |
Will the Idea work - in UK the car uses a wasted spark system
Jan 17, 2010 - 5:58 PM
Will try and get a pic of the engine.
Jan 17, 2010 - 6:03 PM
5s distrib has a primary and secondary coil inside.
Jan 17, 2010 - 7:04 PM
I think it will work.
In UK the 3SFE does not have a distributor. It uses a crank pickup and coil packs instead. The distributor hole is blanked. So fitting a GE cylinder head in place of the FE cylinder head will only create the need for the engine to take in more air which will need more fuel - just the same as forcefeeding the FE engine. Correcting the ignition timing will just make it more efficient. |
Jan 19, 2010 - 7:21 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 2, '05 From Guam Currently Offline Reputation: 15 (100%) |
you just have to convert it to coil pack instead of distributor coil.
Jan 21, 2010 - 2:40 AM
Enthusiast ![]() Joined May 3, '09 From jacksonville/flemming island florida Currently Offline Reputation: 1 (100%) |
i know the later camry 5sfe's had coil packs
-------------------- 94 stx coupe, super mario kart beater
87 toyota 2wd truck, rebuilding engine 85 celica gt-s project |
| Lo-Fi Version | Time is now: August 25th, 2026 - 6:42 PM |
