Jan 23, 2010 - 7:21 AM
Enthusiast ![]() Joined Oct 20, '08 From Lima,Peru Currently Offline Reputation: 0 (0%) |
hey
ive seen ur old treads but non of them answers my question oh 1st of all i have a st202 3sge e56 tranny w/lsd so i guess everybody knows that it really comes from SS(superstrut) variant of st202 ( and non-SS came with s56 with no lsd) well i just said it so theres no confution. it is very very very difficult to me to find axels to this trany ( e56 ), ive looked also at british and japan ebay website with non results. right one is already broken, and left one ...it will get broke soon thought -Does anyone of u guys have e56 axles? -Ive read here somewhere that e153(alltrac) axles will fit e56? is that right? is the same lenght for right and left side? -will other axles fit my e56 ? thanks in advance oh im asking you this so i wouldnt go the dealer and buy these axles if theres another solution. |
Jan 23, 2010 - 5:27 PM
Enthusiast ![]() ![]() ![]() Joined Apr 27, '09 From West Coast Canada Currently Offline Reputation: 0 (0%) |
try posting in the buy/sell forum, Also talk to Vincent_doggy (hes in china? japan? and alot of st202 in yards, he could probably pull a set of axle's for you.
The inner axle's on the E153 are the same, but the out length is different, you would need to use an axel spacer to get it to the correct length. I believe the FWD St215 caldina also uses the same Axles |
Jan 25, 2010 - 9:05 PM
try posting in the buy/sell forum, Also talk to Vincent_doggy (hes in china? japan? and alot of st202 in yards, he could probably pull a set of axle's for you. The inner axle's on the E153 are the same, but the out length is different, you would need to use an axel spacer to get it to the correct length. I believe the FWD St215 caldina also uses the same Axles ill send a msg to him, thanks anyway if anyone knows about this answer please =) |
Jan 25, 2010 - 9:15 PM
Btw, the E153 is a FWD transaxle. That is not in the alltrac.
the E52 and the E56 is practically the same transmission, those are interchangable found them both in the UK http://shop.ebay.ca/i.html?_nkw=st202+cv&a...e&_osacat=0 |
Jan 28, 2010 - 7:47 AM
mmm e52 came with X engine in X car?
actually i found another e56 axle my car is ok now.. but ill research info for anyone that will need it sometime e56 axle has 21 teeth, right side from tranny to the other end has 250.5mm or 255.5mm dont remember also found that cv joint can be put in caldina hub assy, also in 6th gen celicas(japanesse didnt try on americans) guy that sold me the axle told me that a mr2guy broke his right axle too he used alltrac-st185 axle and fit ..need more info about this mmm think thats all for now. |
| Lo-Fi Version | Time is now: August 27th, 2026 - 7:51 AM |
