Jan 30, 2010 - 12:33 AM
Enthusiast Joined Nov 29, '09 From philippines Currently Offline Reputation: 0 (0%) |
I need help on the engine specification, I have a 3SGE - st202 my friend is selling his engine parts of the 3SGTE - st205, I'm planning to turbo it and use the parts from the 3SGTE - st205
Does anyone know the complete engine specification of 3SGE - st202 and 3SGTE - st205?? I need to know also the in/ex camshaft duration and lift of both 3SGE - st202 and 3SGTE - st205? which one is better to use? As I know the cylinder head exhaust gasket of 3SGE - st202 is only asbestos and 3SGTE - st205 is metal. Can I use the metal cylinder head exhaust gasket of 3SGTE - st205 instead? is it direct bolt-on to 3SGE - st202? Which intake manifold is better, 3SGE - st202 has ACIS will it affect the turbo airflow? will it act like a V-TEC of honda to increase power? please help me with my project thank you so much |
Jan 30, 2010 - 5:03 PM
Enthusiast ![]() ![]() ![]() Joined Apr 27, '09 From West Coast Canada Currently Offline Reputation: 0 (0%) |
you can buy a metal HG for either... never reuse an old gasket.
3s-gte Specs Gen3 Manufacturer: Toyota L/CID/VIN: 2.0/122/3SGTE # of cylinders: 4 Bore & Stroke: 3.3858-3.3870" (85.999-86.03MM) x 3.386" (86.004MM) Compression Ratio: 8.5:1 Firing Order: 1-3-4-2 Cylinder Head Thickness: 4.6950-4.6990" (119.253-119.355 MM) Maximum Warpage: .008" Overall (.203 MM) OHC Bore Data: 1.0614-1.0620" (26.96-26.975 MM) Valve Info Installed Stem Height (Intake): 1.4600-1.4850" Installed Stem Height (Exhaust): 1.4700-1.4950" Stem Diameter (Intake): .2346-.2352" (5.959-5.974 MM) Stem Diameter (Exhaust): .2344-.2350" (5.954-5.969 MM) Total Length (Inatke): 4.12600-4.1535" (104.8-105.499 MM) Total Length (Exhaust): 3.8917-3.9193" (98.849-99.55 MM) Angle (Intake & Exhaust): 44.5 degrees Margin (Intake & Exhaust): .020" Min. (.508 MM) Valve Guide Info Guide Height (Intake & Exhaust): .323-.339" (8.204-8.611 MM) Guide Clearance (Intake): .0010-.0023" (.025-.058 MM) Guide Clearance (Exhaust): .0012-.0025" (.03-.064 MM) Spring Info Free Length (Intake & Exhaust): 1.749" (44.425 MM) Installed Height (Intake & Exhaust): 1.354" (34.392 MM) Closed Test Press (Intake & Exhaust): 45-53# @ 1.354" Valve Seat Info Seat Width (Intake & Exhaust): .039-.055" (.991-1.397 MM) Seat Angle (Intake & Exhaust): 45 degrees Valve Lash Info Intake Valve Lash: .006-.010" Cold Exhaust Valve Lash: .008-.012" Cold Cylinder Head Torque Spec. 36 FT/LBS, + 90 degrees Block Info Cylinder Bore Diameter: 3.3858-3.3870" (85.999-86.03 MM) Piston & Pin Info Skirt Oil Clearance: .0028-.0035" (.071-.089 MM) Pin Diameter: .8660-.8665" (21.996-22.009 MM) Pin Type: Float Ring Gap: Top .013-.022" 2nd .018-.026", Oil .008-.024" Housing Bore Info Torque: 43 FT/LBS Crankshaft Info Stroke: 3.386" (86.004 MM) Cylinder Bore: 3.3858-3.3870" (85.999-86.03 MM) Rod Journal Journal Diameter: 1.8892-1.8898" (47.986-48.001 MM) Oil Clearance:.0009-.0022" (.023-.056 MM) Main Journal: Position 1: 2.1648-2.1654" (54.986-55.001 MM) Oil Clearance: .0005-.0024" (54.986-55.001 MM) Crankshaft End Play:.0008-.0087" (.02-.221 MM) Connecting Rods Info Big End Housing Bore: 2.0079-2.0087" (51.001-51.021 MM) Big End Side Clearance: .0063-.0123" (.16-.312 MM) Big End Width 1.055" Torque: 18 FT/LBS, + 90 degrees Small End Finished ID: .8663-.8668" (22.004-22.017 MM) Center to Center Distance: 5.4280" (22.004-22.017 MM) Twist/Bend: .002/.006 @ 3.94 Camshaft Info Cam End Play: .005-.009" (.127-.229 MM) Cam Journal Specs: 1.0614-1.0620" (26.96-26.975 MM) Cam Journal Oil Clearance: .0010-.0024" (.025-.061 MM) |
Jan 30, 2010 - 10:47 PM
![]() Enthusiast ![]() ![]() ![]() Joined Sep 29, '09 From Prince George, BC CANADA EH! Currently Offline Reputation: 8 (100%) |
-------------------- ST205 Crew represent
![]() Challenge Accepted |
| Lo-Fi Version | Time is now: August 26th, 2026 - 6:37 AM |
