> Clutch and Rear Main Seal Install How-To
post May 19, 2010 - 12:08 PM
bsamps4
Joined May 16, '10
From Raleigh
Hello everyone. I'm new to the 6gc world and would like everyone to know how grateful I am for websites like this that offer a wealth of information to consumers. Websites like these not only save you time, but a lot of money as well.
I recently purchased a 94 celica with the knowledge that it needs a new clutch. The car has 215,000 miles, but is still driveable. I can't really have much fun with the car yet due to the fact that the clutch slips in every gear at about 30% throttle. I'm interested to see if anyone would be interested in me making a "How-To" article on the installation of my clutch, rear main seal, and axle. I will need some insight from the senior members of this site ofcourse, but I would certaintly love to start out my celica experience with a bang, and offer some help to other members who may be interested in doing this themselves as well.
I do however have a few questions that I would like to propose for my own personal knowledge. Best transmission fluid? where? how much? Decent brand of axle? where? how much?
The clutch that I will be using is an Exedy stock style clutch which includes pressure plate, release bearing, and pilot bearing, and I will be resurfacing the flywheel NOT replacing. I want to keep my costs as low as possible because I will be swapping a 3sgte dual entry turbo motor into the car in months to come. I will be reusing my 5sfe tranny for the swap, but don't want to cause my current ageing motor to become overstressed, and break unexpectedly.
Let me know what you think, and thanks again!
Replies (1 - 10)
post May 19, 2010 - 2:13 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
Replacing the clutch isn't an easy task - well, actually, it's not hard, per se, but it's labor intensive. I'm not sure if there's an actual "how to" on the site, but if you check the How-To section under Engine/Transmission/Maintenance, there is a link http://www.6gc.net/forums/index.php?showtopic=34164 that has basic info.
When I had to replace my clutch, I actually used the Haynes manual; it's probably one of the few things that the manual was actually really great for. I would strongly advise getting both the Haynes and the Chilton manuals for your car, as sometimes they supplement each other well when one is missing details.
As for how you're going about it, you're already on the right path. I did the same, went with the Exedy OEM style clutch kit, which is key. You absolutely MUST replace the throwout bearing! So many people just opt for the clutch plate, and then wind up having to do the job twice. Lame.
Also, resurfacing your flywheel is totally acceptable if you're not replacing it, which in your case, unless it's just damaged to hell, is totally adequate for your purposes. Again, so many people skimp out on resurfacing the flywheel, which is just a lame thing to do and generally a BAD idea. The flywheel MUST MUST MUST be resurfaced.
I'm not sure what "brand" of axle is best, different people have differing opinions. If it were me, I'd probably just go to NAPA or possibly Autozone and get one. From what I understand, they're fine. But you might want to consider the opinion of others as well before making that decision.
Regarding transmission fluid, I cannot highly enough recommend using Penzoil Synchromesh. A lot of people on the site use it, and in my experience, it is hands-down the best fluid to use for our cars. Autozone carries it (NAPA does not, I don't think). It's a little more expensive than other brands, but I will absolutely attest that I have noticed the difference. When I did my clutch, I used it, but then I had an axle seal go out on me, so I had to drain and refill, but I couldn't get Synchromesh, so I used something else. The result was notchy shifting and just not as smooth transitions. Needless to say the first chance I had, I bought more Synchromesh, and drained it again and refilled it with the Synchromesh, thus restoring the smooth shifts and transitions back to my VERY aged transmission (265k miles and going strong!) Cost is about $8/bottle, you'll need 4-5 bottles IIRC.
Good luck! Oh, and yes, while you're in there, REPLACE THAT REAR MAIN SEAL! Just order that from Toyota, the difference in cost between Toyota and a parts store is negligible, and it's not worth getting an aftermarket brand in my opinion.
post May 19, 2010 - 7:55 PM
samir0189
Joined Mar 8, '08
From Orlando, Florida
welcome.
As far as the axle question, i really like the cardone brand that carquest sells. It is much thicker than OEM and the cv boots have extra pleats. I got it NEW not rebuilt, and no core for $70 ish, i think.
alot of people here seem happy with the synchromesh, i never tried it, i used mobil 1 fully synthetic 75-90 and never had an issue.
My F/S Thread!
Ferdi says (11:29)
post May 20, 2010 - 1:45 PM
bsamps4
Joined May 16, '10
From Raleigh
Thanks to the two of you who have responded. I still think i'm going to do a write up on the procedure, and maybe add some video clips myself. I'm def going to try the synchromesh, and i'll take that axle into great consideration. I live 2 minutes from a carquest, and 2 minutes from a toyota dealership. Love it!
post May 20, 2010 - 5:24 PM
samir0189
Joined Mar 8, '08
Oh! and you may want to replace the axle seals while you are there! I think those were around $12 a side, but get it from toyota!!! I had tried all other auto parts places and no one seems to give the right size seal for the celica. rolleyes.gif
My F/S Thread!
Ferdi says (11:29)
post Sep 15, 2011 - 7:50 AM
foxcraze
Joined Jul 26, '08
From Fort Bragg, NC
ressurection, When replacing the main seal can i take the axle out without being covered in fluid. after i had clutch replaced i forgot to have the seal replaced as well and after a week its now leaking. Can i just raise the drivers side and be safe to remove the axle and not be covered in fluid?
post Sep 15, 2011 - 8:29 AM
bsamps4
Joined May 16, '10
From Raleigh
No. You will need to drain the transmission first, replace the seal, then refill.
post Sep 15, 2011 - 8:55 AM
Keiri
Joined Mar 6, '04
From Charlotte, NC
QUOTE (foxcraze @ Sep 15, 2011 - 8:50 AM) *
Off Topic:
Fox, you back in the States? If so, welcome home and lemme know if you finally want to do that meet-up - I should be in town this weekend and next.
On Topic:
Ben's correct.
Has no more Celicas
post Sep 15, 2011 - 1:34 PM
foxcraze
Joined Jul 26, '08
From Fort Bragg, NC
haha yeah man i am back finally got in a few weeks ago trying to get the car road worthy again lol I will def hit you up once i get this thing fixed i guess i gotta go buy a oil hand pump kit now blahh. thanks fellas
post Sep 15, 2011 - 8:48 PM
KAOS
Joined Apr 18, '06
From Calgary, Canada
QUOTE (foxcraze @ Sep 15, 2011 - 12:34 PM) *
Fox - any chance you have those part #'s handy for the seals?
post Sep 24, 2011 - 3:22 AM
kamax
Joined Apr 29, '03
From lynn,ma
QUOTE (KAOS @ Sep 15, 2011 - 7:48 PM) *
partnumber can be found in this thread if it's any help to you
http://www.6gc.net/forums/index.php?showtopic=67291
Lo-Fi Version Time is now: August 4th, 2026 - 10:03 AM
